Autor Tema: Home made rezonantni auspuh  (Posjeta: 32034 )
Offline Gelipterina
  • Postova: 319
  • Moj Skuter: Peugeot Jet Force
  • Moja Kaciga: Dainese d181
  • MojSetup: u potpisu...
  • MojSpuh: Gianelli Reverse
Odg: Home made rezonantni auspuh
« Odgovori #100 : 10 Prosinac, 2012, 15:01:16 »
Iz mog iskustva, kod promjene sa 50 na 70ccm a da su sve ostale komponente iste, dovoljno je otic za jedan broj gore.  :dontknow: Znaci sa 60 na 62, u tvom slucaju. A sad...
"The basic rules are that if you've fitted a sport pipe the jetting should be increased by 10%, and the only other thing that substantially effects jetting at this level is fitting an aftermarket filter. If you go from 50cc standard cylinder to 70cc sports cylinder you sometimes need to upjet very slightly by perhaps 2, but rarely enough to be of importance unless you're fitting a more highly tuned high revving kit." sa stranice www.pedparts.co.uk
« Zadnja izmjena: 10 Prosinac, 2012, 15:06:08 Gelipterina »
Malossi Sport 70ccm, polirani kanali, Gianelli Reverse, Dellorto 17.5 PHVA TS, getriba +17,5%, Stage 6 Sport Pro vario, pomankuto paljenje, HID...
Offline Kanuni90
  • Postova: 133
  • Mjesto: Brčko
  • Moj Skuter: Kanuni Popcorn 90 cc
  • Moja Kaciga: AGV
  • MojSetup: Serijala
  • MojSpuh: Leo Vince TT
« Odgovori #101 : 01 Siječanj, 2013, 15:49:58 »
Drug, imas li slucajno negdje semu ovog prigusivaca, ja ocu da napravim jos jedan na svoj auspuh, pa me zanima sta ide u njega, pozz
Motor u srcu, brzina u glavi, adrenalin u krvi i ANĐELI čuvari!
Offline dr.mrgood
  • Postova: 1295
  • Mjesto: Bribir
  • Moj Skuter: Peugeot Elyseo
  • MojSpuh: Stock
« Odgovori #102 : 08 Ožujak, 2013, 11:59:33 »
Nema tu seme za prigusivac, rastavis original i napravis isti.
« Odgovori #103 : 08 Ožujak, 2013, 12:08:46 »
Da te pitam, od čega si radil prigušivač?
Offline dr.mrgood
  • Postova: 1295
  • Mjesto: Bribir
  • MojSpuh: Stock
« Odgovori #104 : 08 Ožujak, 2013, 12:15:15 »
Od obicnih zeljeznih cijevi, mada bi svakako bilo bolje da su prokromske. Fino na kraj one savijene cijevi zavaris plocicu sa 3 rupe. Na mitraljezu na oba kraja zavaris plocicu koja ma sebi ima tri vijka m6. Na izlazu iz prigusivaca, na komadic savijene izlazne cijevi isto plocicu sa 3 rupe. Za vanjski plast nadjes cijev koja duljinom tocno odgovara duljini mitraljeza, tako da to dihta kada je sve sklopljeno. A u samom prigusivacu je prvo oko mitraljeza omotana celicna mrezica, a oko toga je namotana celicna zica za sudje, nekoliko puta do potrebne debljine.
« Odgovori #105 : 08 Ožujak, 2013, 12:17:48 »
U biti me zanimalo samo za plašt topa, al ok, barem je sve detaljno objašnjeno :icon_thumright: :icon_biggrin:
Sad vidim da si napisal da je prvo namotana čelična mrežice, pa ona čelična spužva za suđe.
A kamena/staklena vuna?
Ona najbolje upija buku.
Offline dr.mrgood
  • Postova: 1295
  • Mjesto: Bribir
  • MojSpuh: Stock
« Odgovori #106 : 08 Ožujak, 2013, 12:19:29 »
Ma nista nema kamene vune. Znam da ince ide ona al di da ju nadjem ? Ova celicna mrezica za sudje je do jaja, ali mora bit ona skroz fina. Ne sjecam se jesam stavljao video kako mi ide motor sa auspuhom tu , bas cu sad vidit pa ako nisam, stavim.
« Odgovori #107 : 08 Ožujak, 2013, 12:22:28 »
Jesi stavil si.
Vjerujem da ti neko od susjeda ima sigurno koju balu vune viška od nedavne renovacije kuće, pa da ti otkine komadićak :icon_biggrin:
Al ok, ako veliš da nije glasan nema potrebe.
Dihtung si stavil između spoja auspuha i topa?
Offline dr.mrgood
  • Postova: 1295
  • Mjesto: Bribir
  • MojSpuh: Stock
« Odgovori #108 : 08 Ožujak, 2013, 12:26:57 »
Ma nema nikakvog dihtunga, nema potrebe, to je ovaj sprej za temperaturu zadihto, hahaha
« Odgovori #109 : 08 Ožujak, 2013, 12:38:49 »
I ne prdi bez dihtunga??
Onda je 100 % ravno, a to nije ni na jednom aftermarket auspuhu :toothy11:
Offline dr.mrgood
  • Postova: 1295
  • Mjesto: Bribir
  • MojSpuh: Stock
« Odgovori #110 : 08 Ožujak, 2013, 14:43:25 »
Je, ravno je i nis ne prdi, a kako, eto tako, dobro je napravljeno.
