Autor Tema: Wifi ometa tv signal?  (Posjeta: 4644 )
Offline skoda90
  • Postova: 971
  • MojSetup: 1 N 2 3 4 5 6
« : 09 Travanj, 2014, 19:51:41 »
U zadnje vrijeme nemogu gledat tv (digitalni signal) dok mi komp radi,i sad sam skontao da mi ustvari wifi kartica ometa.i prije se to znalo dogadjati ali ne toliko kao sada,u zadnjih 10 dana ako komp radi nema gledanja tv-a.Sto vise wifi kartica prima/salje podatke to je losija slika vecinom ni nema signala.
Kako to rijesiti ima li tko ideju ili je imao takav problem  :dontknow:
wifi kartica je airlive 1600 usb a tv neki lcd grundig (integriran onaj digidatlni reciver)  :icon_scratch:
Offline andy
  • Tržnica : (+17)
  • Postova: 3132
Odg: Wifi ometa tv signal?
« Odgovori #1 : 09 Travanj, 2014, 19:58:09 »
Evo šta manual kaže:
Citat:
If this equipment does cause
harmful interference to radio or television reception, which can be determined by
turning the equipment off and on, the user is encouraged to try to correct the
interference by one or more of the following measures:
1. Reorient or relocate the receiving antenna.
2. Increase the separation between the equipment and receiver.
3. Connect the equipment into an outlet on a circuit different from that to
which the receiver is connected.
4. Consult the dealer or an experienced radio technician for help
Offline skoda90
  • Postova: 971
« Odgovori #2 : 09 Travanj, 2014, 21:03:46 »
Premjestat tv antenu nemogu udaljenos je cca 7-8m isto tako ni wifi karticu nemogu premjestat kao ni tv  :dontknow:
A na istoj uticnici nisu jedino mozda na istom vodu ako je to bitno  :dontknow:
Offline balicdim
  • Postova: 1130
  • master of transakšn
  • Moj Skuter: KTM
  • Moja Kaciga: Nolan N43Air
  • MojSpuh: naTURal
« Odgovori #3 : 10 Travanj, 2014, 07:36:06 »
to je neka tvornička zavrzlama
kod mene je bio slučaj ( a vidio si koliko imam od kompa do tv-a i gdje mi stoji sony) da je ventilator kompa znao usrat signal na tv-u - što je brže radio to je bio lošiji signal
nakon čiščenja kompa sve je radilo kako treba, nije prošlo puno vremena, dok je internet (vip homebox) primao signal, slika je bila katastrofa, upalim wifi sve radi bez ijednog trzaja px-la
izašao je neki update za homebox, sve se sredilo
konkretno u tvom slučaju neznam šta bi moglo bit, no pitat ću banalno pitanje, jesi siguran da je do wifi-ja, probaj iskopčat katricu i nek radi komp i tv bez nje, možda je i kod tebe jedan od ventilatora u kompu krivac
Offline skoda90
  • Postova: 971
« Odgovori #4 : 10 Travanj, 2014, 09:20:57 »
Kakve gluposti nemogu vjerovat,al zanimljivo je sto u mom slucaju slike nestanu na rtl2 i doma,ovo drugo radi  :icon_scratch:
wifi kartica je jer sam prvo skontao kad gasim komp prvo ide log of i vec dodje slika i tako mi dodje ideja pa mozda je wifi i stvarno kad disablam adapter u windowsu evo slike.
Probat cu promjenit kanal na kojem radi wifi pa cu vidit oce se promjenit sta!
a i to s ventilatorima nemos vjerovat  :toothy12:
Offline andy
  • Tržnica : (+17)
  • Postova: 3132
« Odgovori #5 : 10 Travanj, 2014, 09:24:08 »
Na kojim kanalima su ti doma i rtl2?
Probaj nac ta dva programa na drugim kanalima, trebalo bi bit na vise kanala istih programa
Offline balicdim
  • Postova: 1130
  • Moj Skuter: KTM
  • MojSpuh: naTURal
« Odgovori #6 : 10 Travanj, 2014, 10:56:25 »
kod mene su štekali isti programi
neznam gdje ti je okrenuta antena tj prema kojem odašiljaču ali gore na katu imam sve kanale, a u prizemlji nemam domu,rtl2, hrt 3, hrt 4
a kad su štekali programi štekali su ovi gore navedeni
Offline skoda90
  • Postova: 971
« Odgovori #7 : 11 Travanj, 2014, 18:46:33 »
Na 44 kanalu su.
Antena je okrenuta prema vinkovcima (riblja kost)  :dontknow:
Offline balicdim
  • Postova: 1130
  • Moj Skuter: KTM
  • MojSpuh: naTURal
« Odgovori #8 : 11 Travanj, 2014, 21:07:46 »
i kod mene isto
ništa drugo ti ne preostaje već ubacit sobnu pa vidit rezultate
Offline skoda90
  • Postova: 971
« Odgovori #9 : 11 Travanj, 2014, 22:11:47 »
ma prodat cu tv  :toothy12:
Offline Kjaj
  • Postova: 247
  • Moj Skuter: Runner vxr 180
  • Moja Kaciga: Nolan n62
  • MojSetup: serijala
« Odgovori #10 : 13 Travanj, 2014, 12:45:09 »
i meni se ometaju ti signali kad skuter prodje pokraj zgrade  :dontknow:. nije mi jasno zasto
nur langsam
Offline skoda90
  • Postova: 971
« Odgovori #11 : 13 Travanj, 2014, 13:09:09 »
sigurno imaju ngk bez one oznake R  :toothy12:
kad si vec spomenio blizu mene je pruga i kad vlak prolazi (teretni za 20tak vagona) jedno 3 minute nema slike.
Offline Ceki21
  • Postova: 1414
« Odgovori #12 : 13 Travanj, 2014, 13:25:13 »
Kad smo kod tv kanala ima neko da lovi slovence i kud mu je antena okrenuta ?
Trgo - Prijevoz RT
