Autor Tema: LeoVince GP  (Posjeta: 15620 )
Offline Gelipterina
  • Postova: 319
  • Moj Skuter: Peugeot Jet Force
  • Moja Kaciga: Dainese d181
  • MojSetup: u potpisu...
  • MojSpuh: Gianelli Reverse
Odg: LeoVince GP
« Odgovori #20 : 26 Ožujak, 2012, 15:43:02 »
Leo Vince GP Exhaust Review. Any good?
We've had these pipes in for over a year now since they came out.
They've been sitting in the showroom gettin dusty next to the even dustier moped handguards (which Ricky promised us would be a sure seller), so we thought it was about time we ran one up to see what it would do.
To be honest we've never really tried very hard to sell them.
"What's that ?"
"It's the new Leo Vince GP"
"Is it any good?"
"Er...Dunno"
"Have you got any ZX's?"
"Yeah I'll go and get one"
A brief explanation of powerpipes
2 stroke engines are all about the exhaust.
On a regular 4 stroke engine air/ fuel mixture is drawn through the carb into the combustion chamber (cylinder) due to the suction created as the piston goes down.
But if we could cram more mixture into the cylinder than it would normally draw in naturally it makes sense the engine would produce more power.
On a 4 stroke engine we can do this with a turbo charger. A turbine spinning at up to 2,000 times per second stuffs more mixture into the cylinder under pressure than it would otherwise draw in naturally which increases the amount of mixture in the chamber (and effectively increases the compression ratio)
On a 2 stroke engine a perfomance expansion pipe exhaust does something very similar only without any moving parts. When the mixture is ignited on a 2-stroke the piston is forced down... on it's way down, the exhaust port is first uncovered allowing the exhaust gases to escape into the exhaust pipe and then the inlet port is uncovered allow fresh mixture to be drawn into the combustion chamber, but these 2 events overlap. This means that some of this fresh mixture is sucked not just into the cylinder but right through it and leaks into the exhaust pipe.
A well designed expansion powerpipe allows us to make use of this 'waste' to our advantage.
As the fat part of the exhaust reconverges (the back cone) a pressure wave is reflected back through the pipe forcing this fresh mixture back into the cylinder.. This effectively pressurises the cylinder with fuel mixture in a similar way to our turbo. The disadvantage is that a pipe can only work best at a specific rpm because of the timing involved and it takes some considerable skill to fabricate an exhaust which doesn't work well only over a very small rev range.
The pipe...
The pipe itself is very nice looking and probably the only moped exhaust designed to look like a MotoGP aftermarket exhaust. It's E-marked and road legal provided you don't remove the restrictor :)
In usual Leo Vince form it comes with a set of lighter rollers and clutch springs. The body sections themselves are immaculately tig welded stainless steel.
In fact this is its major selling point, stainless steel is expensive but it doesn't rust or corrode anything like a regular powerpipe will. There are virtually no other stainless steel powerpipes in production. With a regular exhaust all you can do is cover it with something to prevent corrosion but whether it's covered with lacquer or chrome plating sooner or later the covering corrodes due to the conditions it operates under leaving a very tatty looking exhaust often within just a few months. The Leo Vince GP should far outlast them.
All sounds good so far, but the most immediately apparent problem with the Leo Vince GP is that in common with standard moped exhausts there simply isn't enough room in it to contain both a full wave expansion powerpipe and a silencer, so compromise must have been made in its design which has to show up in its performance somewhere.
For our testing we used the same Aerox (otherwise standard) as we did for our exhausts comparison article STAGE 6 Pro Replica... to give us some valid comparisons.
http://www.pedparts.co.uk/ekmps/shops/thebikeshop/resources/Design/dyn1.jpg
Results...
Amazingly this pipe was able match the peak power of the best of the other pipes. Let me put that another way, on a standard Aerox this pipe makes as much peak power (7.4hp) as virtually any other pipe on the market !
This means that if setup properly this pipe will perform as well as anything on the market up unto the speed at which the variator can no longer hold the revs constant (approx 35mph).
However as previously discussed we knew this pipe would have to have a performance compromise and this is where it is. As soon as the bike reaches this road speed the only way the bike can go any faster is by the engine revs increasing. If we look at the graph again we see that the power drops off very quickly after 9000rpm. In fact from 9,000 to 10,000rpms it has dropped 4hp from over 7hp to just over 3hp which is going to seriously limit the top speed compared for example to it's Leo Vince ZX big brother and because of this it will even be significantly outperformed by the Leo Vince TT which at £74.95 isn't far off half of its price.
Conclusion... who would buy this exhaust?
The best performing exhausts for an otherwise standard Aerox like a Leo Vince ZX or Stage6 Pro Replica will make maybe 50mph. The Leo Vince GP exhaust will perform identically to these exhausts up to approx 35mph at which point it will start to be significantly outperformed and will not be able to match the same top speed (although the top speed will still be better than standard). Also if you are later looking to upgrade to perhaps 70cc or make further tuning mods this may not be the best exhaust to pick because of its reluctance to rev. These are its only real downfalls.
It should however considerably outlast other exhausts because of its stainless steel construction (especially lacquered pipes) and it should be noted that it would probably work quite well with a gearup kit as that way the revs can be kept lower for longer and the high peak power at lower revs can be utilised to get back the missing top speed. Gear kits don't always work well with standard cylinder bikes but this should work well provided the rider isn't too heavy !
So where were we...
oh yes,
Preuzeto sa: www.pedparts.co.uk
« Zadnja izmjena: 26 Ožujak, 2012, 15:45:20 Gelipterina »
Malossi Sport 70ccm, polirani kanali, Gianelli Reverse, Dellorto 17.5 PHVA TS, getriba +17,5%, Stage 6 Sport Pro vario, pomankuto paljenje, HID...
Offline DinzPula
  • Postova: 164
  • Mjesto: Pula
  • MojSetup: cilindar od matika,radilica od golf 2ke
Odg: LeoVince GP
« Odgovori #21 : 26 Ožujak, 2012, 16:27:33 »
Ja imam yasuni r na serialnom klipu vec dosta i radi ko sat :)
dilajmo za izdilamo.
Offline ivan_speedy
  • Postova: 1253
  • Mjesto: zagreb
  • Moja Kaciga: Held
  • MojSetup: 7,5gr rolice,žuti federi kvačila
  • MojSpuh: LeoVince GP
Odg: LeoVince GP
« Odgovori #22 : 26 Ožujak, 2012, 19:05:21 »
Malo ste me bacili u razmišljanje s tim postovima,kod gp i nije bas nesto  :icon_scratch:
Offline ante tutavac
  • Postova: 182
  • Mjesto: opuzen
  • Moj Skuter: speedfight 2
  • Moja Kaciga: uvex
  • MojSetup: svega isvacega a neide :////
  • MojSpuh: yasuni R
Odg: LeoVince GP
« Odgovori #23 : 27 Ožujak, 2012, 12:50:38 »
stari ja imam yasuni r na sf na serijali sve to lipo postelas i ko grom vrti u pm al i ide kolko je to moguce za serijalu YASUNI R pun pogodak  :icon_thumright: :icon_thumright: :icon_thumright: :icon_thumright: :icon_thumright:
Offline zeezy
  • Postova: 98
  • Mjesto: Crikvenica
  • Moj Skuter: NRG Extreme LC 2000g.
  • MojSetup: Malossi sport 70
Odg: LeoVince GP
« Odgovori #24 : 29 Ožujak, 2012, 00:55:29 »
 imam leo gp na base kitu ja sam zadovoljan,7% duža getriba radi krajnje i ide super...naravno isplati se uzet polovni jeftino jer za cijenu novog ima bolji izbor
Offline ivan_speedy
  • Postova: 1253
  • Mjesto: zagreb
  • Moja Kaciga: Held
Odg: LeoVince GP
« Odgovori #25 : 29 Ožujak, 2012, 10:00:49 »
Znam,novi je oko 1500kn ak se ne varam u benconyu,ali ja ga mogu uzet novog za 1000kn,pa sam pitao dal se to isplati za te pare,jer bi htio nesto tiho ne bas bucno i da je jaci malo od serijskog,tj.da daje malo vece perf.
Offline zeezy
  • Postova: 98
Odg: LeoVince GP
« Odgovori #26 : 29 Ožujak, 2012, 11:04:44 »
pa nije baš tih ako to tražiš...i 1000kn je previše,imaš touring za 600-700kn novi koji je puno tiši a ima slične performanse ili probaj nać malossi wild lion (bačvica) polovni mada ga je teško nać jer ga više nema za kupit-odličan spuh,ja sam ga imao na prije minareliju i stvarno je skuter išao...
Offline ivan_speedy
  • Postova: 1253
  • Mjesto: zagreb
  • Moja Kaciga: Held
Odg: LeoVince GP
« Odgovori #27 : 29 Ožujak, 2012, 11:10:16 »
Ma uzo bi neki auspuh koji bas i ne hrđa,sta ce mi touring kad ce zahrđat ko i serijski,makar se ja ne vozim po kisi,ali uzo bi neki auspuh s kojim bi se rijesio hrđe a gp je taj...
Offline zeezy
  • Postova: 98
Odg: LeoVince GP
« Odgovori #28 : 29 Ožujak, 2012, 11:14:49 »
pa onda uzmi gp, spuh je kvalitetan i lijepo izgleda na skutu,meni do sada nema hrđe nigdje jedino što ti nije tih u odnosu na serijski
Offline ivan_speedy
  • Postova: 1253
  • Mjesto: zagreb
  • Moja Kaciga: Held
Odg: LeoVince GP
« Odgovori #29 : 29 Ožujak, 2012, 11:21:13 »
Uploaded with ImageShack.us
Evo kako to izgleda na sf-u
Offline luka.ck
  • Postova: 869
  • Mjesto: ČK
Odg: LeoVince GP
« Odgovori #30 : 29 Ožujak, 2012, 11:32:15 »
super izgleda speedfight sa tim auspuhom. nemas sta razmisljat. odmah kupi :icon_thumright:
Offline ivan_speedy
  • Postova: 1253
  • Mjesto: zagreb
  • Moja Kaciga: Held
Odg: LeoVince GP
« Odgovori #31 : 29 Ožujak, 2012, 11:44:39 »
:icon_thumright:
Meni se isto sviđa  :headbang:
Offline iabram
  • Postova: 262
  • Mjesto: Sisak
  • Moj Skuter: Baotian BT49QT-9 SPE
  • Moja Kaciga: LS2 FF351
  • MojSetup: 72ccm,bregasta A9,keihin 19mm,malossi multivar
  • MojSpuh: LeoVince Scoot 4T
Odg: LeoVince GP
« Odgovori #32 : 29 Ožujak, 2012, 12:07:57 »
ma ja ne znam sta razmisljas tolko...
super izgleda,a i kolko sam procito to je to sta trazis  :icon_thumright:
