Autor Tema: popis gresaka na ditechu  (Posjeta: 7618 )
Offline ive_91
  • Postova: 1264
  • Mjesto: mjesto Luka
  • Moja Kaciga: takachi tk170n
  • MojSetup: malo je 70
  • MojSpuh: zxulja
« : 20 Svibanj, 2009, 19:50:33 »
ako netko ima da mi tu napise, posalje na mail, msn. ili na pm.
hvala.
Odg: popis gresaka na ditechu
« Odgovori #1 : 21 Svibanj, 2009, 02:00:11 »
c/p ss
sven:
1 Engine overheated - cooler (radiator) damaged
- housing damaged
- not enough water in
radiator (cooler)
- check thermostat and cooler
- check damage on housing
- add some more cooling liquid
2 No signal from electronic
(CDI) for ignition
- Pick-Up cable connected
wrong
- Pick-UP cable damaged
- Check, and replace if needed
3, 4, 5 Nothing to do with engine
errors, etc.. - water on junctions
- check that cables are
connected or damaged
- wait till it drys
- check, check and recheck
6, 7 Error on electronics - water in electronics
- sensor used up
- cdi died
- dry and isolate
- replace
- replace
8 General error in
electronics
- idle throttle higher then it
should be
- cdi died
- reprogram
- replace
9 Error in alternator or in
sensor for current
- empty battery
- contacts on battery loosen
- injectors relays died
- generator died
- recharge or replace
- clean contacts
- check and replace if needed
10 Error in oil pump - pump died
- error in electronic - check
- if so, after reset, the injectio
check should also blink 16x
11 Error in air injector - relays of injector used up - replace
- air injector died
- electronic damaged
- fuses died
- clean or even replace
- reprogram or replace if needed
- replace
12 Error in fuel injector - same as above - same as abve
13 Error on ignition
- cable for sparkplug
damaged
- relays in injector damaged
- cdi died
- check or replace
- go to official servise or replace
- replace
- check fuses or even replace
14 Error in fuel pump - weak battery
- electronic died
- pump died
- replace or recharge
- replace
15 Engine done too much
RPM's (usually after
downhill)
- it means that rpm limitar
worked, that it has been
turned on
- noting wrong, just restart system
4 times to reset that
16 Error on ECU
- error in program - reprogram
18,19 Error in temp sensor
-cable damaged
- sensor died
- ECU died
- check or replace
- replace
20 Error in heat indicator
- cable that is connected to
instrument is damaged
- ECZ died
- check or replace
- replace or reprogram
chupsy
nekome se zna javiti i GREŠKA 21
to je problem sa ECU, zbog vode i pranja miniwashem
srsbk
kad je ve? sve tu napišite i kak se pali injektion chek
chupsy
jednom i za svagda: (jer je negdje neko krivo napisao)
injection check se aktivira tako da pri isklju?enom kontaktu odvreš ru?icu gasa do kraja, te potom daš kontakt, tada ?e se injection check lampica ugasiti kada se ponovo upali pusti se gas! nakon toga ?e lampica po?et blinkat, broje se samo kratki blinkovi a dugi su razmak izme?u dvije greške...
npr. lampica blinka 8 puta pa jednom malo duže pa onda blinka 16 puta
to zna?i da imaš greške 8 i 16
ako nekom nešto nije jasno nek pita na pm
bega
ev možda kad pitam ovo nekom i pomogne...
uglavnom kak se na techu brišu greške,znam da je nešt 3 puta s gasom upalit chek dalje neznam...help thx...
chupsy
upali injection check i pusti da ti 4 puta pro?e sve greške...
najlakše ga je ostaviti da blinka pa do?i za 15 min, ako su greške uredno obrisane onda ?e lampica biti ugašena
Offline neno20
  • Postova: 370
  • Mjesto: Mali Lošinj
  • Moj Skuter: Aprilia sr50 ditech nekad vozio, piaggio typhoon,piaggio nrg trenutni...
« Odgovori #2 : 21 Svibanj, 2009, 11:03:52 »
jel normalno da kada daješ kontakt ti se upali injection check i kada upališ motor odmah ugasi? :icon_scratch:
Offline vladic
  • Postova: 89
  • Moj Skuter: Beberly 250
  • Moja Kaciga: HJC fg 14
« Odgovori #3 : 28 Siječanj, 2011, 19:10:59 »
Evo mog problema. Prekjucer sam opral skuter,ali posteno jer mi sutraa trebal doc kupac, i kad sam ga upalil napravil 1oom i krepa. Uspjel sam ga i izverglati,pa napunil akomulator i danas probam upali i vozi ne dugo jer mi bila zima.Ugasil ga i vise ne pali, pa sam napravil sam onaj test sa zmiganjem lampice.Pokazal mi je greske
9 4 7 8 12 13 5 6 15 18 21  pa kaj je to moguce  :icon_scratch:
ako je molim pojasnite mi jer znam Deutsch a za engleski sam tošo
« Odgovori #4 : 30 Siječanj, 2011, 00:16:19 »
Vecina greski je vezana uz vlagu na kontaktima
Pusti ga da se osusi posteno,na buru ga izvezi :D
Offline vladic
  • Postova: 89
« Odgovori #5 : 30 Siječanj, 2011, 07:57:23 »
A da ga ispusem s kompresorom ili fenom ? :icon_scratch:
Offline wonderkid
  • Postova: 3756
  • Moja Kaciga: !
« Odgovori #6 : 31 Siječanj, 2011, 20:46:43 »
kompresor moze
« Odgovori #7 : 31 Siječanj, 2011, 22:09:16 »
jel proradio
Offline vladic
  • Postova: 89
« Odgovori #8 : 05 Veljača, 2011, 23:18:27 »
Nije.Sve sam ispuhal,nasprical kontakt sprejem.Upali nakon deset pokusaja,ide ko da mu nis nije jedino mu je ler gas pojacan.Kad ga ugasim ponovo ista prica.Dok vergla ko da mu fali benzina,pumpica dela.Chek stalno svijetli.Primijetil sam mu da mu iz auspuha kapne tu i tam crna kapljica.Sad pokaziva greske :9 4 7 8 5 6 21
Offline vladic
  • Postova: 89
« Odgovori #9 : 08 Veljača, 2011, 23:02:53 »
Pa kaj bas niko nezna nis o tome ?
Offline maki 225
  • Postova: 1699
    • http://youtu.be/ATEi_P_i_MM
  • Mjesto: PŽ-okolica
  • Moj Skuter: SR 50 Sport
  • MojSetup: Nema(serijala)
« Odgovori #10 : 08 Veljača, 2011, 23:07:01 »
Da i meni je pokazivao 21grešku al nema je na popisu i nakon 5min sam ponovo očitavao i sve čisto..A isto tako nakon pranja....Probaj promijenit sviječicu tako je i meni baca iskru a nepali..
Offline vladic
  • Postova: 89
« Odgovori #11 : 09 Veljača, 2011, 21:15:57 »
Nova svjecica, stara prica.
Offline Solomon1
  • Postova: 3
  • Moj Skuter: Aprilia Sr 50 Ditec 2003
  • Moja Kaciga: Kacigasta
« Odgovori #12 : 02 Srpanj, 2011, 06:50:15 »
Kako se gasi ona jebena lampica injection check,napravio sam servis i već me polako živcira.Sve radi normalno ali samo ona svijetli,molim za pomoć
