Autor Tema: Setup za Generic XoR  (Posjeta: 11104 )
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
  • Moj Skuter: Keeway 70
  • Moja Kaciga: taiwan helmet
  • MojSpuh: s6 pro replica
Odg: Setup za Generic XoR
« Odgovori #40 : 03 Srpanj, 2008, 00:01:06 »
Zamenis primar ili sekundar u prenosu[produzis za neki zub]
zamenis jednim od ova dva ::)
Offline Fare
  • Postova: 142
  • Mjesto: Nasice
  • MojSetup: Seriala
« Odgovori #41 : 03 Srpanj, 2008, 00:01:33 »
Ovo bi bio moj setup za njega (cjene su sa SA u EUR):
 70CC STAGE6 SPORT PRO            -109,04
 STAGE6 19MM DELLORTO BE        - 84,60
 RACING AIRFILTER MALOSSI E13   - 27,26
 SPORT VARIATOR MALOSSI          - 64,86
PRIMARY GEARING                      - 61,10
STAGE6 PRO REPLICA CE EXHAUST - 120,32
TOTAL                                       - 467,18
E sad sve je pitanje koliko si para spreman uloziti. Ovo su ti cijene sa Scooter attack-a i tu jos moras dodati postarinu i carinu. Ovaj setup sam gledao bas pod generic xor i ovi djelovi su bas za njega i s tim setupom bi mogao potegnuti do recimo 90-100 km/h realne brzine ako se dobro ustima.
Ovo crveno ti je produljenje prijenosa. Laicki prevedeno drugi zupcanici u prijenos, s vise zubi.
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
« Odgovori #42 : 03 Srpanj, 2008, 00:05:14 »
Moze uz obavezno produzenje prenosa :icon_scratch:
Racing cylinder 68cc MALOSSI
MINARELLI horizontal AC
68cc out of the high tech tuning company, MALOSSI puts a lot of bite in your total rpm range. Thermodynamic performance leads to optimal ?every day use“, making it easy to move up to the 68 cubic class. Size does matter!
Iron cast / 47 mm bore / 9.500-10.700 rpm‘s
Pepped up outlet, optimized valve timing, higher compression. Periphery, like exhaust, carburetor and transmission can and should be modified. Maximal speeds up to ca. 95 km/h possible. Not road legal!
SIP-TIPP! Light weight vario rolls, New spark plugs, open manifold/intake are mandatory! Main jet 8-12 % bigger, better 17.5 mm carburetor, longer gears, racing exhaust SPORT.
SIP TUNINGSTEP LEVEL 2/SPORT
A reci ti meni sta sam ja drugo napisao nego u prijevodu isto to.
Nista -samo smo potvrdili isto :laughing7:
Offline Fare
  • Postova: 142
  • Mjesto: Nasice
  • MojSetup: Seriala
« Odgovori #43 : 03 Srpanj, 2008, 00:09:02 »
Tako vec moze, to cjenim kad se slazemo u necemu i kad ne trkeljamo gluposti.  :icon_thumright:
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
« Odgovori #44 : 03 Srpanj, 2008, 00:10:04 »
Offline roby44
  • Postova: 1500
« Odgovori #45 : 03 Srpanj, 2008, 01:41:41 »
evo moj setup na xor-u.
malossi gus
malossi vario
dellorto 17.5
ZX
krajnja 90 po GPSu, ide kao bilo koji minarelli s istim setupom.
i ja sam mislio stavit minarelli masinu ali sam odustao i slozio ovaj setup jer nema smisla utuc tolko para u skuter, na kraju sam ipak zadovoljan dobivenim jer suter ide, zainat svima koji su govorili da bacim u smece!
Sorry ali po satu 90 s tim setupom OK, ali po GPS-u nema sanse!!!! Prelistaj malo forum i pogledaj sta je HAC morao napraviti od svog Trekkera da bi dobio 107 po GPS-u pa onda pricaj kako tvoj sa gusom i zx-om ide 90. Sorry ali ne moze!!!
inace to je realna brzina za ovaj setup, onaj ko s ovim setupom nema tu brzinu ima lose postelan skuter i gotovo.
znam sta je HAC radio...
+/- 2-3km, mjereno je autom.
ali poanta ovoga uopce nije brzina nego razno razna trkeljanja onih koji nikad nisu slagali taj skuter nego imaju pametne izjave tipa kupi piagio i sl. za koje vec imas bezbroj gotovih setupa pa sve to samp popikas na skuter i ide.
ovo nije taj slucaj, to je kopija minarellija i treba malo improviziranja i kemijanja al da se slozit.
Offline ichko
  • Postova: 1181
  • Mjesto: Kotor, Montenegro
  • Moj Skuter: Generic xor and custom project
  • Moja Kaciga: AGV K Rossi zoo
  • MojSetup: Malossi sport 70
  • MojSpuh: Polini 4race
« Odgovori #46 : 03 Srpanj, 2008, 08:42:35 »
Hvala vam puno ljudi,kad se odlucim za rabotu javljam vam se da mi pomognete oko kupovine djelova...
Offline pitaNS
  • Postova: 2154
  • samo gas
  • Mjesto: Novi Sad
« Odgovori #47 : 03 Srpanj, 2008, 08:51:34 »
ajd da se nadovežem na priču s obzirom da se radi o Stage6 setupu, mislim na cilindar i spuh! Juče ja u gradu a neki aerox zuuuu ispred mene i ja po gasu i stignem ga, pitam za setup i kaže mi da ima taj....
i mi tu malo se zezali jedan pored drugog i po ubrzanju nije ništa spektakularan u odnosu na moj sa stock cilindrom, samo sa aupuhom....Ne znam, možda mu je raštelovan scoot, jer nešto jako slabo ide... :dontknow:
« Zadnja izmjena: 03 Srpanj, 2008, 08:53:35 pitaNS »
Offline ichko
  • Postova: 1181
« Odgovori #48 : 12 Srpanj, 2008, 14:05:13 »
Sto mislite o ovom setupu
stage 6 70ccm alu
stage 6 pro replica auspuh
malossi multiva
karb 19
radilica TNT
delta i wingbell
kais 800/17 umjesto 788/17
primar i sekundar
Oce li ovo bit ok,mislim jel dobar ovaj spuh za ovaj kit,mislim isto su stagee 6 pa sam ih zato spojio
Rece kureee dea je ovaj kit sa 1 karikom i trazi auspuh za visoke obrtaje tako nesto,pa mislim da je ovaj spuh ok,a sad me interesuje kakvog je kvaliteta ovaj kit,kolko moze trajat i to,znam da je alu pogodniji za razradjivanje i zagrijavanje ejr toga bukvalno i nema...aj da cujem misljenja i predloge...
Evo opet da napisem masina je kopija minarelija,znaci cpi/keeway/generic/luna....
Offline Crazy Kuree
  • Postova: 3127
  • Mjesto: Orašje
  • Moj Skuter: Neos LC
« Odgovori #49 : 12 Srpanj, 2008, 16:41:05 »
savršeno bi radio sa nardom ili shotom a taj radi na oko 10500 što i nisu neki obrtaji
Offline ichko
  • Postova: 1181
« Odgovori #50 : 12 Srpanj, 2008, 19:26:39 »
Ali nardo i shot imaju dosta jacu cijenu od njega sto mi bas i ne pase,jedino polovni negdje naci,ali gdje pitanje je veliko
Offline Crazy Kuree
  • Postova: 3127
  • Mjesto: Orašje
« Odgovori #51 : 12 Srpanj, 2008, 19:38:13 »
novi Shot je 1350kn
