Autor Tema: runner 50sp 07.god. service manual  (Posjeta: 4501 )
Offline ivansp
  • Postova: 256
  • Mjesto: sb
  • Moj Skuter: gilera runner 50sp
« : 30 Siječanj, 2011, 18:07:29 »
dali netko ima service manual za runnera 2007. godina
Offline Zucho
  • Postova: 118
  • Moj Skuter: Trenutno ga nemam
  • Moja Kaciga: Glavu cuva
Odg: runner 50sp 07.god. service manual
« Odgovori #1 : 31 Siječanj, 2011, 18:07:22 »
Imam ja u papirnatom izdanju na hrvatskom, kaj te zanima, da ne skeniram cijelu knjižicu.
"Glupost je nesalomljiva: sve što naleti na nju mora se razbiti."
  • Postova: 15041
« Odgovori #2 : 31 Siječanj, 2011, 18:16:38 »
Imas service manual, ili korisnicki manual?
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #3 : 31 Siječanj, 2011, 18:17:29 »
sheme instalacija i sl....
« Odgovori #4 : 31 Siječanj, 2011, 18:22:26 »
  • Postova: 15041
« Odgovori #5 : 31 Siječanj, 2011, 18:23:51 »
Ovo ti je od starog runnera, al vjerojatno je isto/slicno:
1. Horn. - 2. Headlight with two 12V-15 bulbs - 3. Front turn indicators, with 12V-10W bulbs - 4. Brake light/engine start permissive button  (rearbrake). - 5. Brake light/engine start permissive button (frontbrake). - 6. Keyswitch. - 7. Instrument panel: three 12V-1.2W bulbs (instruments) and five 12V-1.2W indicator bulbs (fuel warning - mixer oil warning - lights - rh turn indicator - lh turn indicator) - 8. Lights selector switch. - 9. Turn indicator selector. - 10. Horn button. - 11. Start button. - 12. Rear turn indicators, 12V-10W bulbs. - 13. Thermistor - 14. Contactor - 15. 7.5 A fuse  - 16. Fuel warning light transmitter. - 17. Mixer oil warning light transmitter. - 18. Starter motor. - 19. Automatic choke - 20. Magneto. - 21. Pick-up. - 22. Spark plug. - 23. C.D.I. module. - 24. Voltage regulator with built-in turn indicator flasher unit. - 25. 12V-4Ah battery - 26. Rear light, 12V-5/21W bulb (side light and brake light).
B=White - Bl=Blue - G=Yellow - Mr=Brown - N=Black - BV=White-Green - GN=Yellow-Black - Gr=Grey - Rs=Pink - R=Red - Vi=Purple - V=Green - VN=Green-Black - BN=White-Black - BBl=White-Blue - GV=Yellow-Green - Ar=Orange - GrBl=Grey-Blue - GrN=Grey-Black.
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #6 : 31 Siječanj, 2011, 18:24:17 »
od starog sam skinuo al nema nigdje za 2007 god.
« Odgovori #7 : 31 Siječanj, 2011, 18:26:28 »
a kaj te točno zanima, pola nas ti ima manuale u glavama  :icon_biggrin:
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #8 : 31 Siječanj, 2011, 18:29:25 »
neradi mi brzinomjer digitalni,tj. stojhi na 0 stalno a tip mi je reko da su zamjenjene dvije žice,e sad il on priča gluposti ili je stvarno a neznam kako u stvari treba biti....ugl...
« Odgovori #9 : 31 Siječanj, 2011, 18:31:32 »
i meni je bilo vrisnulo to, el puž sa kotača.. e sad pitanje jel to tebi baš crklo ili ..
Offline Luksy
  • Postova: 1808
  • Mjesto: Šibenik
  • Moj Skuter: Gilera Runner sp
« Odgovori #10 : 31 Siječanj, 2011, 18:32:46 »
jesi ga kupija polovnog pa je neko dira oko tih zica ili ti je odjedanput prestalo radit
PRODAJEM
Dijelove:GILERA 98-05
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #11 : 31 Siječanj, 2011, 18:35:10 »
kupio sam polovnog i tip od kojeg sam uzeo je reko da mu je crklo nakon servisa jer je ovaj vald mrdo oko žica i zamjenio neke dvije...to je sve što znam....ali broji mi kilometre tako da sumnjam da je puž,a sad da kupim novi sat i samo da probam dal je do njega....šta ako nije onda sam popušio pare...
Offline Zucho
  • Postova: 118
« Odgovori #12 : 31 Siječanj, 2011, 18:35:41 »
Ma korisnicki, moja greska!
« Odgovori #13 : 31 Siječanj, 2011, 18:36:39 »
broji kilometre a ne pokazuje brzinu? onda je do sata..
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #14 : 31 Siječanj, 2011, 18:38:48 »
onda kupit sat pa vidit nemam šta drugo....teško da mogu negdje posudit sam da probam sat...
« Odgovori #15 : 31 Siječanj, 2011, 18:40:12 »
imaš rabljenih satova po oglasniku... kupi sa čim manje km  ;D
  • Postova: 15041
« Odgovori #16 : 31 Siječanj, 2011, 18:41:16 »
novi sat je vjerojatno jako skup.
Probaj naci polovni, a moj savjet ti je da sa prodavacem dogovoris da ga isprobas prije kupnje, pa ako ti ne odgovara, das mu nesto novaca za trud, a ti onda trazis gresku negdje drugdje
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #17 : 31 Siječanj, 2011, 20:42:48 »
zašto sa baš što manje km.a jbg..našo sam jedan tu na forumu traži 200kn al on iz zg ja iz broda i jedino mogu riskirat nikako drukčije.jel zna neko s koje godine je sat sa bijelom podlogom jer obično je crna podloga na obrtaljki.....
http://img824.imageshack.us/i/p1020837.gif/
ovaj sat
« Odgovori #18 : 31 Siječanj, 2011, 20:44:52 »
ovo je od NRG-ja, crni je od runnera... al mislim da paše..
Offline ivansp
  • Postova: 256
  • Mjesto: sb
« Odgovori #19 : 31 Siječanj, 2011, 20:47:44 »
onda je tip mjenjo sat,jer ima još dijelova a svi su od runnera
