Autor Tema: BT125T-3A2 Baotian, utisci  (Posjeta: 7436 )
Offline gotoo86
  • Postova: 29
  • X-SERVER TEAM
    • xserver.netii.net
  • Moj Skuter: BT125T-3A2 Baotian; Aprilia AF1 pro sport
  • Moja Kaciga: Uvex 3000
« : 04 Ožujak, 2010, 11:11:45 »
Molio bih da mi neko da svoja iskustva i misljenje o ovom skuteru je sam ga kupio pre neki dan... pa svaki komentar je dobro dosao, da znam na cemu sam ;)
Model:BT125T-3A2
1. The first 150CC patent model in China, the second company who develop models independently.
2. The scooter design totally improved according to the Honda original model. The European customer who abandons Chinese thinking designs it and it meets the European style.
3. The engine totally improved according to the Honda original engine, water-cooled 150cc, has great power. The mold of the complete vehicle is developed and manufactured by our company that enjoys a good consistency and easy control.
4. Mix the speciality of scooter and motorcycle, it is easy to handle and stable.
5. The front and rear brake performs in high consistency, which add the safe system.
6. Front and rear shock absorber totally improved according to the original ones' technical parameter.
7. In order to solve the problem when using ethanol gasoline in Europe, the engine, carburetor, filter and the muffler were carefully matched. The power of engine is guaranteed.
8. The model meets the E3 standard. For the national manufactory, it is a singular model.
9. 16 inch new style big tyres give you strong absorb to the ground and driving more steadily and safely. The seamless thicker steel tube and thicker frame promise the safety.
10. Using the LED tail lights.
11. The EC certificate of 151cc, can ride on the high way.
12. Using the high quality aluminum rear connecting board which greatly improve the safety.
« Zadnja izmjena: 02 Travanj, 2010, 15:17:19 gotoo86 »
X-SERVER TEAM. No1 cardsharing team
Offline eladio
  • We are the Borg
  • administrator
  • Postova: 9355
  • Moj Skuter: Xciting 400i
  • Moja Kaciga: SMK Hybrid
  • MojSpuh: Yasuni black ed.
Odg: BT125T-3A2 Baotian, utisci
« Odgovori #1 : 04 Ožujak, 2010, 11:25:43 »
Koliko si ga platio.. ?
To je karb verzija ako se ne varam i ima disk iza ?
Gledao sam ga tj. pricao s vlasnikom jednoga takvog prije nekih pol godine i mislim da uopće nije toliko loš skuter, ide 100+ km/h, malo troši , itd..
Iako tu ima i drugih dobrih skutera u klasi..
Ovisi koja ti je namjena , ali mogao bi te dobro sluziti..  :hello:
Offline gotoo86
  • Postova: 29
  • X-SERVER TEAM
    • xserver.netii.net
« Odgovori #2 : 04 Ožujak, 2010, 11:29:24 »
pa po meni su prvi utisci ok, iz pre ruke mogu da kazem da da ide bez problema 100 km/h a moze i jos malo vise, jedino sto me zabrinulo je batrija mu je nekako slaba, cini mi se da par puta ako ga zaverglas da ce se potrositi.... ima jako dobar zvuk, a i izgledom je po meni skroz ok.... za gradsku voznju je ok
a placen je 1200e na snizenju, inace je oko 1500e
pozdrav
« Zadnja izmjena: 04 Ožujak, 2010, 11:32:51 gotoo86 »
Offline wonderkid
  • Postova: 3756
  • Moja Kaciga: !
« Odgovori #3 : 04 Ožujak, 2010, 12:10:27 »
vidio sam takve u beta moto u svetoj nedjeli i jako lijepo izgledaju i iza su imali disk
Offline gotoo86
  • Postova: 29
  • X-SERVER TEAM
    • xserver.netii.net
« Odgovori #4 : 04 Ožujak, 2010, 12:22:49 »
Podsjcaju na beverlya, a nisu skupi :)
I da imaju diskove i napred i pozadi
Offline legi
  • Postova: 74
« Odgovori #5 : 27 Ožujak, 2010, 11:21:08 »
Kad napraviš nešto kilometara, napiši malo detaljnije iskustva, bilo bi zanimljivo. Ovako po slici izgleda lijepo.., vuče na neke model, ali koji ne vuče  ;D..
Offline gotoo86
  • Postova: 29
  • X-SERVER TEAM
    • xserver.netii.net
« Odgovori #6 : 02 Travanj, 2010, 15:26:25 »
evo ovako, presao sam nesto vise od 600 km sa njim jos malo na prvi serivs, al do sad sam u potpunosti zadovoljan, imao sam manji problem cim sam ga kupio, dobio sam uz njega pokvaren akumulator al to su mi odmah zamjenuli cim sam primjetio. motor ide odlicno, vrlo dobro ubrzava, a masimalna brzina koju sam ja postigao je 105 km/h... potrosnja mu se krece od 3 do 4 litre na 100km. isao sam sa njim i na relaciju od 90km u komadu i nazad 90km prezivjeo je i to... tako da, za sad sam zadovoljan..... u stvari jedina zamjerka na motor jeste alarm, pisti ko lud...ebemu sve pisti 3 puta kad ugasis motor, pisiti ako ostavis kljuceve, pisti kad zakljucavas i kad otkljucavas.. to me stvarno nervira :) al nije strasno
Offline eladio
  • We are the Borg
  • administrator
  • Postova: 9355
« Odgovori #7 : 02 Travanj, 2010, 15:31:14 »
iskljuci alarm (i zbog akumulatora)
i pomalo jos razradi motor, jos nema ni soma vec mu trazis granice  :icon_biggrin:
Offline gotoo86
  • Postova: 29
  • X-SERVER TEAM
    • xserver.netii.net
« Odgovori #8 : 02 Travanj, 2010, 15:40:05 »
rado bih ga isklucio da znam kako, cekam taj prvi serivs pa cu im eci da ga iskljuce... al ako nije nesto komplikovano slobodno me uputite :D
o ovom se uredjaju radi, i koliko vidim moze se tu iskljuciti zvuk
http://www.steel-mate.com/product.php?pid=597486&lang=enus&cid=75716&product=Remote_engine_start,_for_KTM_motorcycle
« Zadnja izmjena: 02 Travanj, 2010, 15:52:00 gotoo86 »
Offline pixa.93
  • Postova: 900
« Odgovori #9 : 02 Travanj, 2010, 15:56:57 »
znaci za te novce cistsoldan gradski motor
Offline eladio
  • We are the Borg
  • administrator
  • Postova: 9355
« Odgovori #10 : 02 Travanj, 2010, 16:02:10 »
ma samo istekaj jack   :icon_thumright:
u biti mozda ce ti onda trebati jedna zica za conectat paljenje  :icon_scratch:
Offline tonch08
  • Postova: 208
  • Be cool.
  • Mjesto: Virovitica
  • Moj Skuter: Piaggio NRG MC2 DD
  • Moja Kaciga: Custom Made
« Odgovori #11 : 19 Srpanj, 2010, 13:56:04 »
cuj kinez je... ko i ova 2 moja sto iam...  :icon_biggrin:
al kako se ono kaze "novo je novo" tak da te ceka jos 20k km :D
samo ga odrzavaj kak se spada, i imat ces ga ko gilleru...
Offline PROOF
  • Postova: 3920
  • aj ne seri jeate
  • Mjesto: Varazdin-Vratno
  • Moja Kaciga: head inside
« Odgovori #12 : 19 Srpanj, 2010, 14:59:34 »
ali nikad nece ic ko gilera :D
ĐITN ĐITN......
FUCKING ZAŠIKJENIC :ajdeajde:
PIČKIN PRDEC
Offline _nino
  • Postova: 63
    • Sibenski List
  • Mjesto: Sibenik
  • Moj Skuter: Beverly ST 350
« Odgovori #13 : 29 Srpanj, 2010, 20:59:59 »
Potpis  :headbang:
Offline animatrix
  • Postova: 3829
  • Mjesto: Vukovar
  • Moj Skuter: Luna Vision II
  • Moja Kaciga: Vemar TAI2K
  • MojSetup: DR Evo 70cc AC
  • MojSpuh: TT
« Odgovori #14 : 30 Srpanj, 2010, 01:33:52 »
ok, koju gileru iz trgovine mozes kupiti za 10000kn? NIJEDNU
da uzmes runnera 50 polovnog za te pare, opet, trosi vise, skuplje odrzavanje, slabiji motor, manja krajnja
Offline _nino
  • Postova: 63
    • Sibenski List
  • Mjesto: Sibenik
« Odgovori #15 : 30 Srpanj, 2010, 01:45:23 »
da, to sam i ja govorio prije par godina dok nisam sjeo na posten skuter/motor... nebi vise kineza pa da je i mukte...
Offline animatrix
  • Postova: 3829
  • Mjesto: Vukovar
  • MojSpuh: TT
« Odgovori #16 : 30 Srpanj, 2010, 02:05:46 »
a jbg, pa normalno da je bolje, al najlakse je govoriti ljudima da su kinezi sranje, a vecina vas koji imate talijane su druga il treca ruka, stari preko 5god, dok mi vozimo nove skutere...
Offline _nino
  • Postova: 63
    • Sibenski List
  • Mjesto: Sibenik
« Odgovori #17 : 30 Srpanj, 2010, 02:28:46 »
ja sam bome na svom prvom kinezu u godinu dana napravio skoro pa 10.000 km tako da pouzdano znam da je kinez sranje. Jos s tim ako uzmemo u obzir da mi je odmah drugi tjedan nakon sto sam ga registrirao pukla radilica, nemamo vise sto za dodati. I da, moj talijan je novi i iz prve je ruke :)
Offline animatrix
  • Postova: 3829
  • Mjesto: Vukovar
  • MojSpuh: TT
« Odgovori #18 : 30 Srpanj, 2010, 02:44:02 »
pa eto, ja na 12000+ sam imao problem sa namotajima i cdi-jem, to sam nedavno rijesio, sve ostalo je sipaj i vozi.. opet ona, ovisi kako naletis... ma nebitno, ovaj kinez sa pocetka teme mi se cini kao odlican ulov, za 10k nov skuter nemozes bolji dobiti, bolji je od 50ki u svakom pogledu.
