Autor Tema: ulje u vilicama-problem  (Posjeta: 1161 )
Offline gun_rider
  • Postova: 1390
  • Moj Skuter: cvajo 180
  • Moja Kaciga: imam
  • MojSetup: a
  • MojSpuh: imam
« : 08 Rujna, 2009, 14:49:50 »
radi se o skuteru malaguti warrior, paioli vilice
rastavia sam gornji dio za nadolit ulje...međutim nešto ni nije jasno
evo šta piše u manualu
FORK OIL:
Level check
Oil level inside the legs must be
checked in case of fork always
bottoming or of abnormal noise being
detected.
Proceed as follows:
•remove the upper cap (A).
•remove seeger ring (B) by pushing
cap (C), complete with O-ring (D),
downwards by using a screwdriver.
•Carefully move out the spring (E),
allowing the oil in which it is immersed
to drip off.
•Bring the inner tube (F) to end-oftravel.
•Keeping the leg perfectly upright,
introduce a meter or gauge stick and
check for correct oil level, which
should 105 mm below the top edge
of the inner tube (F. 21).
•Top up if necessary (see lubricant
chart).
•Perform the same steps on the other
leg.
e sad ono šta me brine...koliko sam ja svatia...unutrašnji tub treba stisnuti do kraja...međutim onda nema 105mm do vrha ili više...nego ima možda 70-80mm...a vilice nikad nisu otvarane, čuju se, otvrdnule su...jedino šta mi je logički da unutrašnji tub netreba stisnut do kraja nego izvuć pa onda mjerit razinu ulja??
nikad nisam radia ovo pa ako neko zna bia bi mu zahvalan
Servis skutera, lakiranje i popravak plastika na podrucju Splita i okolice
Info na PM ili 098/979-8453
