Autor Tema: Dimenzije remenja za minarelli - info  (Posjeta: 22905 )
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« : 27 Siječanj, 2009, 19:55:30 »
Za sada raspolazem sljedecim informacijama koje se ticu minarelli horizontal masine:
Serijski remen orginal Yamaha: 3AA-17641-00, dimenzije: 751X16.50 mm
Stage 6 remen za Aeroxa: 16,5x747
Stage 6 remen za Yamaha Axis, Breeze, Zest, Jog: 16,5x792
Stage 6 remen za Malaguti F12 '92-'94 - 16,5x792
Da li netko slucajno zna dimeznije TOP performances, Malossi X kevlar, Hebo remena? Topov remen i kevlar cu imati prilike izmjeriti, ali dobro bi mi dosao i podatak.
Offline dhorvat
  • forumski cruiser
  • Postova: 6892
  • Moj Skuter: YaAeMrAoHxA
Odg: Dimenzije remenja za minarelli - info
« Odgovori #1 : 27 Siječanj, 2009, 20:04:11 »
Hm, TOP remen ima neku čudnu dimenziju 738 x 16,5 x 28. Kaj god do značilo  :dontknow:
EDIT:
pogledaj i ovdje:
http://www.martinracingdealer.com/CategoryProductList.jsp?cat=Parts+by+Type%3AKevlar+Belts&offset=36
« Zadnja izmjena: 27 Siječanj, 2009, 20:06:17 dhorvat »
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
  • Moj Skuter: Keeway 70
  • Moja Kaciga: taiwan helmet
  • MojSpuh: s6 pro replica
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #3 : 27 Siječanj, 2009, 20:26:11 »
http://www.wms-online.de/product_info.php/cPath/400_118_401_91/products_id/991
http://www.wms-online.de/product_info.php/cPath/400_118_401_91/products_id/858
http://www.wms-online.de/product_info.php/cPath/400_118_401_91/products_id/1102
Naso nesto malo :icon_thumright:
a naso sam sve malossijeve na gomili :icon_biggrin:
http://www.malossi.com/news/newsDoc/PDF_PRODOTTI%5CDIM%20CINGHIE_001.pdf
Ocekivao sam tvoj odgovor  :notworthy: :notworthy: :notworthy:
Zahvaljujuci "cvele60" saznao sam neke nove stvari  :notworthy:  :headbang:
Dimenzije malossi x kevlar remena za aeroxa: 746,5x16,5-30
Malossi special belt: 744x16,5-30
Sad mi je jasno zasto mi je topov remen "ukrao" dio krajnje brzine...
« Zadnja izmjena: 27 Siječanj, 2009, 20:37:01 SlowRider »
Offline dhorvat
  • forumski cruiser
  • Postova: 6892
« Odgovori #4 : 27 Siječanj, 2009, 20:39:37 »
Pa podjeli to s nama. Ima nas koji bi voljeli i to znat  :toothy3:
Misliš radi dimenzije? (738)
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
« Odgovori #5 : 27 Siječanj, 2009, 20:46:35 »
E sad Slow,malo to preradi pa stavi u FAQ,al ne zaboravi i kratki mina[to ja zbog kineza] :icon_tongue: :icon_thumright:
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #6 : 27 Siječanj, 2009, 20:51:28 »
Nije da mislim nego sigurno znam i uvjerio se, nikada vise nisam izganjao prijenos kao sa kevlarom... I kada stavim tanku sajbicu pod variomat (0.2mm), remen mi nije skroz na vrhu polutki, kada bih imao remen koji bi bio iza na vrhu, to bi bila dobitna kombinacija  :frajer:
Evo vec je ubacen link u tvoju temu, ako tema dobro zavrsi staviti cemo je cijelu :icon_thumright:
Jos samo da mi je saznati dimenzije Hebo remena.
Citat iz teksta Skuter prijenos: "Za 10 eura više dobije se s njim i Hebo Special Belt (kevlar) koji je duži od originalnog zbog čega se može potpuno iskoristiti veći promjer variomata."
« Zadnja izmjena: 27 Siječanj, 2009, 20:55:51 SlowRider »
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
« Odgovori #7 : 27 Siječanj, 2009, 21:10:02 »
Taj duzi Hebo ide u kompletu sa variom,i valjda je  :dontknow:  sam vario malo vecih dimenzija od ostalih,valjda ide i ventilvar.
Ne bi bilo logicno -duzi remen a sve ostalo isto :icon_scratch:
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #8 : 27 Siječanj, 2009, 21:37:39 »
Situacija je ovakva. Multivar ne dize remen do vrha variomata, ima nekih 3mm...
U minarellija se variomat moze stelati pomocu tankih sajbica koje se podloze izmedju bolcne variomata i ventilatora na radilici. Kada kupis novi remen, recimo kevlar ili TOP koji je sirok 16.5mm, on nece upasti skroz do kraja u variomat i time imas duzi prijenos u startu sto rezultira losijim startom. Zato je potrebno kada imas novi remen, staviti tanku sajbicu (imam set sajbica razlicitih debljina) da remen upadne skroz u variomat. Ali onda remen nije skroz na vrhu zadnjih polutki. Znaci, ili tamo ili vamo nedostaje...
smatram da bi duzi remen to nadoknadio.
Malo fali, ali promjena se jasno osjeti i nije nimalo zanemariva:
Za sada su mi zanimljiva ova 2 remena:
http://www.wms-online.de/product_info.php/cPath/400_118_401_91/products_id/1104
iako pokusavam saznati preostale 2 dimenzije koje nisu navedene.
« Zadnja izmjena: 27 Siječanj, 2009, 21:46:51 SlowRider »
Offline cvele60
  • Postova: 2307
  • Mjesto: Nis
« Odgovori #9 : 27 Siječanj, 2009, 21:58:56 »
Da sto se sajbnica tice tu si u pravu,isprobao sam par remena i tako ih stelovao.Probao sam i remen za piagio 804-18[serijski mi je 788-17,al mu uvek fali 5-6mm do vrha multivara] i tek sa njim sam izbacio remen do kraja[i dobio par km]
Racunao sam da je problem mozda u lose odradjenim polutkama kod kineza,mada sad nisam siguran dal remen silazi do kraja,
s obzirom na to da je ipak duzi 16mm od orginala :toothy11:
 Mislim da ovaj polinije prvi vise odgovara zbog sirine :icon_thumright:
« Zadnja izmjena: 27 Siječanj, 2009, 22:01:31 cvele60 »
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #10 : 27 Siječanj, 2009, 22:32:21 »
Stavio sam 4 remena u uzi izbor, mislim da cu 2 izabrati, prije toga cu provjeriti jos neke stvari na prijenosu koje bi mogle utjecati na izbor dimenzije remena...
Offline dhorvat
  • forumski cruiser
  • Postova: 6892
« Odgovori #11 : 27 Siječanj, 2009, 22:46:57 »
Imam jedno pitanje za vas, cvele i slow:
TOP remen kad je bio novi imao je najjaču krajnju (i malo lošiji start radi širine remena), a Malossi X-Special i Polini Kevlar su mi identično u postocima ukrali krajnje  :icon_scratch: Znači novi remeni koji su mi ukrali više krajnje nego 0,3 mm potrošen TOP remen. Mogu dobit kakvo objašnjenje?  :confused5:
  • Postova: 15040
« Odgovori #12 : 27 Siječanj, 2009, 22:49:18 »
TOP remen kad je bio novi imao je najjaču krajnju (i malo lošiji start radi širine remena), a Malossi X-Special i Polini Kevlar su mi identično u postocima ukrali krajnje  :icon_scratch: Znači novi remeni koji su mi ukrali više krajnje nego 0,3 mm potrošen TOP remen. Mogu dobit kakvo objašnjenje:confused5:
Topov je duzi. Nema druge. Mozda se rastego pa zato, ali jedini razlog je duzina
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #13 : 27 Siječanj, 2009, 22:55:28 »
Po mojem iskustvu za 2 kevlara, uvijek im je trebao duzi period da se prilagode, u samom pocetku znaju dosta narusiti setup prijenosa. Znam samo da sam bio jako razocaran kada sam tek stavio topov remen, iako je on sjeo na svoje mjesto, ali opet nije kao kevlar. Ne mozes to saznati u kratkom periodu.
Topov je kraci.
« Zadnja izmjena: 27 Siječanj, 2009, 22:57:52 SlowRider »
  • Postova: 15040
« Odgovori #14 : 27 Siječanj, 2009, 22:58:09 »
Topov je kraci.
Nema logike, jer kraci remen ne moze doci do vrha varia jer pu zadnje polutke ne daju. Ako ej dosta dugacak, onda mu to nije problem.
Offline dhorvat
  • forumski cruiser
  • Postova: 6892
« Odgovori #15 : 27 Siječanj, 2009, 22:58:34 »
Pa rastego se sigurno, ali je i novi imao istu krajnju  :dontknow:
Jer ako gledamo dimenzije onda nema smisla ništa. 738 mu je dužina, a 751 remen je kraći po toj logici  :icon_scratch:
Znaš kaj ja mislim. Da je debljina (ne širina) remena drukčija. I da je TOP možda TANJI i zato bolje sjedne na radilicu i visoko na polutke, odnosno visoko na variomat i duboko u polutke. Jel to moguće?  :jerk:
  • Postova: 15040
« Odgovori #16 : 27 Siječanj, 2009, 23:00:24 »
Moguce ukoliko ga variomat unatoc njegovoj maloj sirini moze stisnut do kraja odnosno da variomat sam sebi ne smeta u tome (da takne nepomicnu polutku prije nego remen bude gore)
Offline SlowRider
  • Tržnica : (+33)
  • Postova: 7664
« Odgovori #17 : 27 Siječanj, 2009, 23:00:40 »
Topov je kraci.
Nema logike u tom slucaju (dhorvat)...
u mom slucaju ima logike...
Izmjeriti cu pa cemo vidjeti...
« Zadnja izmjena: 27 Siječanj, 2009, 23:02:54 SlowRider »
Offline dhorvat
  • forumski cruiser
  • Postova: 6892
« Odgovori #18 : 27 Siječanj, 2009, 23:08:23 »
Jer ako nije onda bum dofural svoj remen na mjerenje, izgleda da ja začaran  :laughing7:
Offline dionysus_
  • Postova: 96
  • Moj Skuter: Luna Vision 2
  • MojSetup: --
  • MojSpuh: leo vince tt
« Odgovori #19 : 27 Siječanj, 2009, 23:24:46 »
evo još jedne dimenzije za mina horizontal: 788-17 to je za lunu vision 2
koji remen mi preporučate, mislim da ima još mjesta na variu, tj. da se ovaj ne popne do kraja
duži - širi?  duži - uski?
kad nemam niš pametnog za pisat pišem gluposti
