Autor Tema: Iskustva s najnovijim ledicama za glavna svjetla  (Posjeta: 122895 )
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
  • Moj Skuter: Smart 451
Odg: Iskustva s najnovijim ledicama za glavna svjetla
« Odgovori #260 : 27 Prosinac, 2020, 19:53:52 »
Ima li netko preporuku za H7 mini(da mogu stat u leću),nemoraju biti najjeftinije
« Odgovori #261 : 28 Prosinac, 2020, 16:16:05 »
Ove su zanimljive, bacaju na sve 4 strane.
https://www.ebay.com/itm/360-4-Side-H7-CSP-LED-Headlight-Fog-light-Mini-Bulbs-100W-18000LM-6000K-Canbus/123876063494?hash=item1cd796b906:g:FxkAAOSwNEVdVeG3
Pogledajna aliexpressu za ovakve, ividi za recenzije kako zaista svijetle jer nemam iskustva s njima. Cijena im ne ide u prilog, jer sve sta sam jeftino placao na ebayu od ledica to mi je dosta brzo crklo, a ovo dole u nastavku imam vec godinama i koristim dosta
ALI, mislim da nemas jacih od ovih, XHP70, znaci ovo napravi brasno od mraka, imam ovakve u maglenkama i to nadjacava sve. Znaci provjerena jaka roba.
https://www.ebay.com/itm/CREE-XHP70-car-LED-Headlight-CANBUS-Bulb-H4-H7-H8-H9-D1S-D2S-auto-light-fog-lamp/274565266804?hash=item3fed5d7d74:g:hfQAAOSw0cVdbc6D
Ako ti je to puno para, ove su malo slabije, ali isto jako dobre i snazne, XHP50:
https://www.ebay.com/itm/Car-CREE-XHP50-LED-Headlight-bulb-12000LM-4300K-H4-H7-H11-D2S-D1S-Auto-lamp-fog/274046203682?_trkparms=ispr%3D1&hash=item3fce6d3722:g:PhoAAOSwzFxa8qBZ&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkY3FSd4Ad8xn3oRtkVexxrJVRrDienE0UI7II%252BO7ot2aMzEAPChKKE6QfwJF%252F6f1MnNqpGbod3GNwtY0vRuJK9ho5qcW81F8JEa%252FZJYNJCGldSzX6eFxZWtlAfpPQ2Z8Gsl1nS5BaDOZFdP%252FUm82jDH4iMykqrFtdXfHSYjjdukWCwR7gna3yn5efY%252FfhUpUvhiHc4UfPZkE8BHZKaHMp78fwkvfqPbw3htZXp%252FwrjCFxY1F78aobmdzd0Ky4BzCQaXfpEPYpm4m0z7hoR%252F%252Ft2liHRt4TFYe%252FYrvYlFgoVL317SLG2i%252Bw3sdkQV2Cfpvd43gaNMLHgFK%252Be%252BvWLbKMLBcefUxHj1mRo8D4OVPHGioJVbz6eZcU4bFP7Dov6uo1LhdWCYhdX7p8zAxzTnTuj7BKU2XSejnOYszhfJobXdai9F%252BtchZnZS%252FyGg633rcdlg0y7nXsjZ7umYifBTm%252BO%252BUR7yQ2IHODfLJE6GrWe4Nw%252F1w%252B9jSzw%252BL9N%252FjAjZW26zkYA9ktAmun82CwGSV9f20Js9b%252BsM%252FSyNLYzzcivQ%252FkYxi1Oj%252BLHfKU%252BkALMbSA5yx22JMbQ8QH08AHTEhNJAawGBJ56MEigXUTHq%252Fm%252FuihnmnBfki3DlkfhjYNCS8lsA3MciUP80PnfqFuBNVZtHXNkh6XmhJZHtX%252BKidhOL34wE%252FElYpW74S54haeBnaD%252B84oCMdH4QuWwDlcxcGve4rbn7jbGfoNhlkSDsyvOZMVAgOkDQ0jf8lhdT2LRB531P6vV5N6njd8XQlcrq7uXw%253D%253D%7Ccksum%3A2740462036824b40da3864d645f3bea499b4dd55d640%7Campid%3APL_CLK%7Cclp%3A2334524
« Zadnja izmjena: 28 Prosinac, 2020, 16:21:05 Corector »
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #262 : 28 Prosinac, 2020, 16:40:22 »
Hvala corector extra odgovor
Ove najskuplje nemaju ventilator ili..
Stavljao bi ih na smart 451 nema puno mjesta u faru...
 :hello: :laughing7:
« Odgovori #263 : 28 Prosinac, 2020, 16:50:50 »
Opaa, onda stavljaj ove XHP70 sto sam ti linkao, nemaju ti ventilator, te su najbolje s tim srebrnim trakama koje odvode toplinu, njih savijes okolo jer su fleksibilne i zauzimaju manje mjesta od ventilatora.
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #264 : 28 Prosinac, 2020, 17:02:06 »
Aha znaci trake sluze za odvod topline,reci mi koliko se takav tip ledice grije naspram halogenke,tj strah me da neotopi sjelnilo
P.s. smart ima leću,zato je prostor ogranicen
« Odgovori #265 : 28 Prosinac, 2020, 18:26:08 »
Vidio sam da ima lecu. Grije se dvostruko slabije od halogenke. Kad sam imao xenon s vremenommi je lagano topio plasticna sjenila u skuteru, a ovo ne radi probleme.
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #266 : 28 Prosinac, 2020, 18:42:52 »
Xenon sam imao na e90,tako da bi sada probao led
« Odgovori #267 : 28 Prosinac, 2020, 20:15:31 »
Evo slike od Danijela 4x4 kako svijetle ledice H4 s lecom. On je ugurao obje u far od Runnera 50.
Ovdje su obje istovremeno
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #268 : 28 Prosinac, 2020, 20:19:47 »
Fenomenalno,cak imaju i cut efekt  :hello:
« Odgovori #269 : 28 Prosinac, 2020, 20:27:48 »
Imaju da. Nece mi nesto video dici gdje se vidi kako obje rade na 50ccm Runneru. A na Peugeotu rade probleme jer nema dobru struju kao talijan.
Offline donkeko
  • Postova: 24
  • Nije u soldima sve e....
« Odgovori #270 : 28 Prosinac, 2020, 21:35:22 »
Sve je to lijepo cuti i vidjeti ali mene su vratili sa tehnickog radi led svijetala tako da sam morao vratit normalne sijalice i tada su me pustili.
Dalmatinac nosi lancic oko vrata nosi more u svom srcu....
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #271 : 28 Prosinac, 2020, 21:37:56 »
Hvala na info   :icon_thumright:
Prije teh vratimo halogen i tjt  :hello:
« Odgovori #272 : 28 Prosinac, 2020, 22:05:26 »
To se podrazumijeva da se ide na svoju ruku :D
« Odgovori #273 : 28 Prosinac, 2020, 22:22:20 »
Izgleda jebeno.... Dal znas koje su tocno? na ebay-u ih ima puno razlicitih
Offline di.ky.73
  • Postova: 1075
  • Mjesto: DU
« Odgovori #274 : 28 Prosinac, 2020, 22:25:50 »
Ledice su jednostavno buducnost,tako da ce vjv uz neki certifikat postat legalne...sve vise novih auta ima led rasvijetu
  • Postova: 2952
« Odgovori #275 : 29 Prosinac, 2020, 07:42:53 »
to ce se desiti nikad
cijelo svjetlo mora biti homologirano za led
Offline dinko1981
  • Postova: 130
  • Moj Skuter: batina
« Odgovori #276 : 29 Prosinac, 2020, 08:19:55 »
Zapravo se nedavno desilo, Osram je izbacio prve h7 led koje su legalne za cestovnu uporabu. Za sada je to dopustenje ograniceno samo za Njemacku i za sacicu modela sa spiska za koje su homologirali, ali to je vjerovatno tek pocetak...
https://www.osram.com/ecat/NIGHT%20BREAKER%20H7-LED-LED%20high%20and%20low%20beam%20lamps-Car%20lighting-Automotive/com/en/GPS01_3401765/
  • Postova: 6117
  • Samo Kawasaki
  • MojSetup: Originalni
« Odgovori #277 : 29 Prosinac, 2020, 09:11:26 »
Čisto sta sam vidio
Frend ima auto školu i kupio krimpirvagen golf 8 i auto ima led zarulje u obicnom faru. Znaci tak je dosao iz tvornice. Svjetle brutala sad nisam htio haubu dizat i pogledat u faru sta je to unutra.
Znaci izgleda da i takve stvari rade.
Ps znaci nisu led matrix svjetla ona lijepa s lecom nego bas halogene lampe s led zaruljama
« Odgovori #278 : 29 Prosinac, 2020, 09:43:26 »
Eto sta radi biznis.
Offline Infernus
  • Postova: 949
  • Tjuner bez kune
  • Moja Kaciga: imam dopunsko
  • MojSpuh: tutuz replica
« Odgovori #279 : 29 Prosinac, 2020, 11:36:51 »
Ove ledice mi izgledaju ko da bi mogle dobro radit u projektorima (farovima s lećom), imaju najmanju "žarnu nit" koju sam do sad vidio na žaruljama tog tipa.
https://www.ebay.com/itm/H1-LED-Headlight-Bulb-Specially-For-Projector-Lens-70W-8000LM-Car-Light-Retrofit-/324117293127?_trksid=p2349624.m46890.l49292
...još to iskombinirat s 3" projektorima s ebaya (kao bi-xenon set za utrpat u tvorničku lampu, može ić h1 halogenka ili xenon žarulja unutra i obično idu po 35 usd na ebaju) i to bi moglo bit jebeno. Šteta kaj ih ne rade ispod 5500k, to je isto sumnjivo plavkasto za tehnički i policajce
Forumska Sirotinja R/T
