Ostalo > Svijet računala i mobitela
garmin mobile na n 95
<< < (2/2)
Josip:
a ok,jel to možda N95 koji je tomma prodavao i jeli on to sam stavljao? ???
..::Alf::..:
Evo budem ti ja malo pomogo!!!
Evo ti link od adria routeove karte, to ti je najbolja karta za RH!!
http://www.navigo-sistem.hr/index.php?page=product&pid=5&cid=83&id=296&sid=eb3dbc276428a3d82bfaa47251b42787
Skidaš ovu mobile XT verziju
Kaj se tiće GPSa, uz program si sigurno dobio KEYGEN i upute, pa probaj nać taj KEYGEN, a evo ti šta trebaš radit:
Garmin Unlock Generator v1.3
This keygen will generate unlock codes both for device and locked maps using Garmin format.
Instructions to generate device unlock code for GMXT:
1.  Download and install Garmin Mobile XT.
2.  Extract the archive to your storage card.
3.  Insert your storage card into your PPC, when prompted, install the application.
4.  Launch GMXT, got to Settings -> About.
5.  Make note of your "Card ID"
6.  Launch the keygen, and type in your "Card ID" into the "Unit ID" field.
7.  Hit Generate button to generate device unlock key.
8.  Copy (CTRL+C) your generated device unlock key to the clipboard.
9.  Now open the Notepad and paste (CTRL+V) the key and save the file as SW.UNL
10. Put your newly created file to your SD Card\Garmin directory and restart GMXT.
1. Launch the keygen and enter your 10# GPS Unit ID (or GMXR Card ID, Unlock ESN).
2. Select Map product and hit the corresponding Generate button to generate both Device & Map unlock key.
NOTE: If your map is not included in the Map product list, select <custom mapset>, enter the corresponding MapID and hit OK.
      If you are not sure about your MapID, install it first into the MapSource, open regedit and browse for
      one of the following keys:
      [HKEY_LOCAL_MACHINE\SOFTWARE\Garmin\Mapsource\Families\<YOUR MAP>]
      or
      [HKEY_LOCAL_MACHINE\SOFTWARE\Garmin\Mapsource\Product\<YOUR MAP>]
      and check the "ID" REG_BINARY. That is your MapID (in HEX). You have to convert it
      from HEX to decimal (do not forget to reverse the byte order when coverting)
3. Hit Generate button to generate map unlock key.
4. Copy (CTRL+C) your generated map unlock key to the clipboard.
5. Open the Notepad again and paste (CTRL+V) the key and save the file as GMAPSUPP.UNL
6. Put your newly created file to your SD Card\Garmin directory and restart GMXT.
This keygen is also compatible with Garmin MapSource application. You can use it to generate map unlock keys
for any Garmin GPS device and any map using Garmin IMG format.
Ja sam to probo na svojoj E65, ali mi ne radi jer nema GPS, tebi bi moralo radit..
Nego reci koji si program skino, jel to onaj Multilanguage, pa di imaš i Hrvatski??
Josip:
da program je multilanguage,jel mi možeš detaljno objasnit preko pm-a,nisam ni ja neki stručnjak u ovaj mobitel :laughing6:? :toothy9:
..::Alf::..:
--- Citat: Josip - 29 Ožujak, 2008, 19:48:34 ---da program je multilanguage,jel mi možeš detaljno objasnit preko pm-a,nisam ni ja neki stručnjak u ovaj mobiteal :laughing6:? :toothy9:
--- Kraj citata ---
A jebiga, nemogu ti baš objasnit, kad meni neradi, zbog drugih razloga, al eto!!
Uglavnom imaš tam folder sa garminovom ikonom i zove se keygen ili garmin keygen, otvoriš ga i sad će te tražitunit ID here, a naći ćeš da tak da dođeš u Garminu u Setings ili neš tako piše al na hrvatskom i upišeš tu tamo taj kod. Nemoj taj broj zamjenit sa IMEIom!!! On će ti dat neki kod, koji kopiraš u notepad, taj folder nazoveš SW.UNL i kopiraš ga na karticu u folder garmin!! Ispod te pita ta kartu. Znači ideš na <custom mapset>, tu te traži kod, koji je za onu Adria routeovu kartu 708. Opet ti da neku šifru, kopiraš ju u notepad, nazoveš ju GMAPSUPP.UNL i kopiraš isto u Garmin skup s kartom!!!!
Mislim da bi ti nakon ovog trebo nać GPS interierni i da će onda otvorit i kartu!!!!!
ak ti otvori, uživaj, ak ne jebiga žao mi je, ja ti nemogu više pomoć.
evo ti još jedan link, tu imaš malo o tom Garminu
http://www.symbian-freak.com/forum/viewtopic.php?t=13252
Josip:
riješio :toothy9: :toothy9:nemogu skinut osmjeh s lica :laughing6:hvala svima :headbang:
Navigacija
[0] Lista Poruka
[*] Prethodna stranica
Idi na punu verziju
