Autor Tema: runner 180 sp blokovi  (Posjeta: 920 )
Offline šajstor
  • Postova: 37
  • Mjesto: Starigrad
  • Moj Skuter: Runner 180 sp
  • Moja Kaciga: airoh domesquad
« : 22 Travanj, 2014, 12:59:50 »
pozdrav ljudi dali mi neko moze rec na kolko Nm se stezu  blokovi na 180 sp
ako imate bilo sto jos za dodat u vezi stezanja ili opcenito djelova, alata za koristiti, slobodno :)
Offline IceMan
  • Postova: 1657
  • Black Bird
  • Moj Skuter: Piaggio Zip 2t
  • Moja Kaciga: IXS HX 253
  • MojSetup: Polini Hi speed
  • MojSpuh: Leo Vince RR
Odg: runner 180 sp blokovi
« Odgovori #1 : 22 Travanj, 2014, 14:31:43 »
ovisi o matici
evo ti tablicu mozda ti pomogne, vrijedi za suhe i ociscene navoje  :icon_thumright:
http://www.cncexpo.com/MetricBoltTorqueNm.aspx
Piaggio Zip 50 2t
Offline walkay
  • Postova: 5428
  • Dr. TGB
« Odgovori #2 : 22 Travanj, 2014, 17:13:01 »
Blokove na 12-13 Nm
Glavu na 10-Nm...
Evo sve za FXR-SP180
PART a.ty                                                         Tightening torque N·m
M Engine assembly
M1 Cylinder head nut 4                                                 10 - 11
M2 Coolant bleed screw 1                                               6 - 7
M3 Temperature sensor 1                                               6 - 8 '
M4 Crankcase assembly screw 8                                    12 - 13
M5 Transmission case assembly screw 15                       12 - 13
M6 Pick-up screw 2 3 - 4 M7 Stator screw 3                      3 - 4
M8 Intake manifold screw 2                                           12 - 13
M9 Starter motor screw 2                                             12 - 13
M10 Fuel/oil mixer screw 2                                               3- 5
M11 Rear hub cover screw 5                                          13 - 15
M12 Driving pulley screw 1                                             75 - 80"
M13 Driven pulley screw 1                                              52 - 56"
M14 Kick-start lever screw 1                                           12 - 13
M15 Rear hub oil drain screw 1                                         3 - 5
M16 Clutch nut 1                                                           55 - 60
M17 Mixer plate screw 1                                                    3 -4
M18 Spark plug 1                                                           25 - 30
M19 Head coolant union screw 2                                         3-4
M20 Flywheel cover screw 4                                               1 - 2
M2 1 Flywheel fixing nut 1                                                52 - 56"
M22 Transmission cover plate screw 6                                  3- 4
M23 Transmission cooling cover screw 4                               3 -4
M24 Water pump impeller 1                                              0.5 - 0.4
M25 Cylinder head screw 4                                                  8 -10
Exhaust manifold-cylinder nut 2                                           9 -11
Exhaust manifold-exhaust pipe nut 2                                  10 - 12
Exhaust pipe-engine screw 2                                              22 - 24
Offline šajstor
  • Postova: 37
  • Mjesto: Starigrad
« Odgovori #3 : 22 Travanj, 2014, 21:57:58 »
fala puno  ;D
