Autor Tema: Blic pitanja  (Posjeta: 1808898 )
« Odgovori #8480 : 19 Ožujak, 2019, 08:09:32 »
Auto Dario u Trnskom?
Bio prije mjesec dva (jer je zadnja guma na motoru bila previse potrosena za teh. pregled kojeg sam imao neki dan), da ih uhvatim prije preseljenja u Slavonsku aveniju i ulovio ih zadnji tren. Taj novi ducan/radiona jos nije sluzbeno otvorena. Udruzili su snage sa Matkom iz Splita (Motobox) i otvara se ducan/radiona i pitanje dana kad bu sluzbeno otvorena, mozda vec i sad rade tamo.
I pokazalo se kao dobra odluka, jer sam sa tim gumama napravio vec 1600km jer je veljaca bila ljetno izdanje  ;D
Ovo je istina, uskoro otvaraju na Slavonskoj, tu kod Partesa ako se ne varam.
Offline shogun
  • Postova: 585
  • Mjesto: zg
  • Moj Skuter: runner 50 sp
  • Moja Kaciga: Shark Sqwal
  • MojSetup: 70cc jeftini
« Odgovori #8481 : 19 Ožujak, 2019, 08:14:06 »
Wd ne sluzi za podmazivanje
Wd je sredstvo za ciscenje sa natrijevim kloridom poznatim kao sol
Tako da pazite kud spricate wd 40
« Odgovori #8482 : 19 Ožujak, 2019, 08:33:49 »
WD-40 is the trademark name of a penetrating oil and water-displacing spray. The spray is manufactured by the WD-40 Company based in San Diego, California.[1]
WD-40's main ingredients as supplied in aerosol cans, according to US Material Safety Data Sheet information, are:
    50% "aliphatic hydrocarbons". The manufacturer's website claims this ratio in the current formulation cannot accurately be described as Stoddard solvent, a similar mixture of hydrocarbons.[16]
    <25% petroleum base oil. Presumably a mineral oil or light lubricating oil.
    12–18% low vapor pressure aliphatic hydrocarbon. Reduces the liquid's viscosity so that it can be used in aerosols. The hydrocarbon evaporates during application.
    2–3% carbon dioxide. A propellant which is now used instead of the original liquefied petroleum gas to reduce WD-40's flammability. (A bulk liquid version, without a propellant, is also manufactured for industrial use.)
    <10% inert ingredients.
sta bi sol radila u wdu, nema smisla
Offline BP
  • Postova: 319
  • Moj Skuter: Runner 180
  • MojSpuh: Pipe Design Hornet
« Odgovori #8483 : 19 Ožujak, 2019, 09:32:37 »
Ma kakav wd, samo ZOK40 :) :)
Tko hoce probat ZOK neka se javi. Dat cu mu probni uzorak, garantiram da je bolji od WD-a
Offline shogun
  • Postova: 585
  • Mjesto: zg
« Odgovori #8484 : 19 Ožujak, 2019, 10:00:48 »
gledao sam na galileju, i procitao negdje na nekoj stranici, sad idme trazit i ne mogu da me ubijes
« Odgovori #8485 : 19 Ožujak, 2019, 10:29:50 »
Da ali svakako wd nema soli niti ce unistit ista, i osim toga primarna svrha mu nije ciscenje nego podmazivanje i zastita od vode i korozije
« Odgovori #8486 : 19 Ožujak, 2019, 11:01:55 »
Wd pozuti. Zasto ne bi kupili silikonski sprej i kraj price?
« Odgovori #8487 : 19 Ožujak, 2019, 11:30:09 »
Meni je ok na crnom auspuhu nista se ne vidi, svakako se moze i motornim uljem mazat i slicno, bitno da je masno i odbija vodu/vlagu
« Odgovori #8488 : 19 Ožujak, 2019, 13:58:48 »
Sta ima neki silikonski za visoke temp?
Offline shogun
  • Postova: 585
  • Mjesto: zg
« Odgovori #8489 : 19 Ožujak, 2019, 15:38:45 »
zagladio sam rubove na dr evo u cilindru
treba li jost sta
« Odgovori #8490 : 19 Ožujak, 2019, 15:43:54 »
Diht masa na alu brtvu izmedu cilindra i bloka s obje strane, izmedu glave i cilindra nemoj mazat
Offline TopPerfomance4
  • Postova: 1065
  • Moj Skuter: Piaggio Nrg
« Odgovori #8491 : 19 Ožujak, 2019, 18:32:24 »
to ti je to montiraj kit neka ti odradi po 3 puta 30min s tim da se termogrupa mora potpuno ohladit ne prelazi pola gasa jedno prvih 100 km prvih 150 je najteže onda fino krene
« Odgovori #8492 : 19 Ožujak, 2019, 18:52:32 »
Je bokte,sat ipo na leru... Pusti ga 20 min na leru i lagano razraduj,50km po gasa i do 100km lagano opterecuj motor, poslije samo gass
  • Postova: 1113
« Odgovori #8493 : 19 Ožujak, 2019, 19:03:23 »
Jel' ima ?
« Odgovori #8494 : 19 Ožujak, 2019, 21:25:58 »
Ja sam svoj naspricao sa onim berner silikonskim kog sam spominjao i nakon voznje auspuh i dalje ima onaj blagi "masni" sloj na sebi kada ga dotaknes sto znaci da nije ispario i obavlja funkciju. U slucaju da je neka mrlja na njemu samo je zbrisem maramicom i to je to. Nista ne ostaje. Probao sam prije njega colmaxov silikon sprej ali je taj brzo izlapio, ni jednu voznju od 10 minuta nije izdrzao.
« Odgovori #8495 : 19 Ožujak, 2019, 21:43:23 »
I nakon koliko vremena ti nestane taj zastitni sloj?
« Odgovori #8496 : 19 Ožujak, 2019, 22:16:32 »
Ne vozim se pa to nisam jos utvrdio. Zasad je nekih 2h radnog vremena izdurao a vidjeti cemo za dalje.
  • Postova: 1113
« Odgovori #8497 : 21 Ožujak, 2019, 10:27:07 »
Zna li neko na prvu koji skuteri imaju isti ili sličan agregat ? Skuter je od kolege, Pegasus STM SM50, minareli, ali u katastrofalnom stanju. Treba mu za prvu ruku ventilator variomata i remen.
« Odgovori #8498 : 21 Ožujak, 2019, 11:43:27 »
pa ako znaš da je minarelli zašto onda pitaš  :sad1: aerox, sr50, neos, beta ark, yamaha slider, jog, malaguti mislim da su svi sa minarellijem doalzili, itd itd...
  • Postova: 1113
« Odgovori #8499 : 21 Ožujak, 2019, 11:46:56 »
Ja imam Morini i nem pojma kako se Minareli pravio, ima li razlike u dijelovima i sl. Ako je svaki 2T Minareli isti, super.  :)
