Autor Tema: eBay/Aliexpress/Skuter shopovi - fancy stvari, dobre ponude, popusti, akcije  (Posjeta: 349807 )
Odg: Ebay fancy stvari
« Odgovori #620 : 12 Svibanj, 2018, 11:44:52 »
sad bi mi svi trebali stavit diznu na puhalicu ak nezelimo prevec ulagat (neka potrebstina)
https://www.ebay.com/itm/Air-Power-Siphon-Engine-Oil-Cleaner-Gun-Cleaning-Degreaser-Pneumatic-Tool-Hose/201970760806?hash=item2f06653c66:g:u08AAOSweZJaM7pN
Narucio ovu glupost bas da vidim jel to kaj valja
« Zadnja izmjena: 12 Svibanj, 2018, 23:39:04 zvonkec92 »
« Odgovori #621 : 21 Svibanj, 2018, 09:07:12 »
« Odgovori #622 : 21 Svibanj, 2018, 10:17:50 »
Kopiro bi Zvonkecov text iz posta iznad uz moju narudzbu ;D
https://m.ebay.com/itm/Auto-Green-2A-Lead-Acid-Battery-Desulfator-12V-24V-36V-48V-Golf-Car-Boat-/263340265049?txnId=2228989388016
Procitaj pa vidi jel ti pomaze  :icon_thumright:
Sulfation occurs when a lead acid battery is deprived of a full charge. This is common with starter batteries in cars driven in the city with load-hungry accessories. A motor in idle or at low speed cannot charge the battery sufficiently.
What is sulfation? During use, small sulfate crystals form, but these are normal and are not harmful. During prolonged charge deprivation, however, the amorphous lead sulfate converts to a stable crystalline and deposits on the negative plates. This leads to the development of large crystals that reduce the battery’s active material, which is responsible for the performance.
There are two types of sulfation: reversible (or soft sulfation), and permanent (or hard sulfation). If a battery is serviced early, reversible sulfation can often be corrected by applying an overcharge to an already fully charged battery in the form of a regulated current of about 200mA. The battery terminal voltage is allowed to rise to between 2.50 and 2.66V/cell (15 and 16V on a 12V mono block) for about 24 hours. Increasing the battery temperature to 50–60°C (122–140°F) during the corrective service further helps in dissolving the crystals.
Permanent sulfation sets in when the battery has been in a low state-of-charge for weeks or months. At this stage, no form of restoration seems possible
« Odgovori #623 : 21 Svibanj, 2018, 23:24:47 »
Moj je stajo na camcu spojen na motor 8mj pa ga je posisalo i "trajno" ubilo- plan mi je probat ovu magicnu kutiju cisto da se uvjerim da cuda (ne) postoje pa ce onda na Resnik sa jednom hrdjavom izresetanom bacvom 200l i jos ponesto gvozdjurije :)
« Odgovori #625 : 31 Svibanj, 2018, 06:40:59 »
« Odgovori #626 : 05 Lipanj, 2018, 10:38:01 »
j#bo im isus mater, ovi s carine skoro svaki paket otvaraju i uzimaju proviziju za to u zadnjih mjesec dana. Plus, carinili mi paket od 162kn i uzeli 102kn sveukupno troskova.j#bo ti bog mater pa necu vise nista narucivat iz principa da im j#bo bog isus majku krvavu. Ma mrs pi*ka vam materina ove sekunde se odjavljujem
« Zadnja izmjena: 05 Lipanj, 2018, 17:18:13 Corector »
« Odgovori #627 : 05 Lipanj, 2018, 12:27:40 »
gotovo je, sta smo narucivali narucivali smo... ja sad zadnje sta sam uzimo sve su sitnice do 30kn, ako mi na to naplate carinu i pdv necu nista platit. bolje ostat bez 30kn nego lopovima dat jos 70-80
« Odgovori #628 : 05 Lipanj, 2018, 12:31:06 »
Ja se taman spremam na veliki shoping, cca 1500kn razno raznih stvari da budem miran za sljedećih nekoliko godina :toothy12: Posljednji trzaji
« Odgovori #629 : 05 Lipanj, 2018, 15:56:30 »
Ma ja sam iz trzaja odj#bo, nedam ti harac da je ne znam sta, al snaci cu se.
Offline dario3
  • Postova: 84
  • Moj Skuter: Peugeot SF 2
« Odgovori #630 : 05 Lipanj, 2018, 16:53:41 »
Ne bi smjeli cariniti do 160 kn pakete. Po kojem je to zakonu
« Odgovori #631 : 05 Lipanj, 2018, 17:17:49 »
« Odgovori #632 : 05 Lipanj, 2018, 17:52:25 »
uvatilo te za par kuna, jebiga, nisi imo srece, ali, takav je propis i sve je po zakonu  :(
Inace, to ce bit i za sve manje iznose od 160kn, ali mislim tek od 2020. (ili2019?) godine (PDV  + troskovi+postarina+pickematerine koje ce jos izmislit)
Offline dario3
  • Postova: 84
« Odgovori #633 : 05 Lipanj, 2018, 18:01:16 »
To ce vrijediti i za pakete iz EU?
« Odgovori #634 : 05 Lipanj, 2018, 18:03:50 »
ne (osim ako se ne radi o bescarinskoj zoni koju kinezi i ostali koriste u EU da namame kupce). Ali obicno ako pise kod kupovine da je iz EU i da nema oporezovanja, onda je gotovo u pravilu tako. Ako ti je sumnjivo niska cijena, bolje se prije raspitat, nije se jednom desilo da u dobroj vjeri kupis nesto sto je nazivno iz EU, a da te carina opali po djepu
ali....situacija...
neka pi*darija u kini kosta 2 dolara, besplatna postarina. Isto to u EU na ebayu kosta 7-8 dolara. To je puno skuplje. Ali, ipak ce bit jeftinije nego 2 dolara +PDV+troskovi oporezovanja i postarina od carine do tebe (ti troskovi ce biti uzas, jer su 50-60-70-80kn bez obzira na cijenu proizvoda)
jbg, nakupovat tih sitnica prije nego stupi na snagu, a nakon toga placat skuplje u EU
« Zadnja izmjena: 05 Lipanj, 2018, 18:10:02 3alfa3 »
  • Postova: 6049
« Odgovori #635 : 05 Lipanj, 2018, 19:31:15 »
Corector tebi su samo pdv naplatili, carine nema na tako mali iznos. To je sve po propisu, inace takvi paketi prolaze ali jbt nisi imao srece...hahah
« Odgovori #636 : 24 Lipanj, 2018, 13:14:29 »
Pijani Kinez :icon_scratch:
« Odgovori #637 : 24 Lipanj, 2018, 14:53:29 »
Hahahahahaha hoce pa nece  :laughing7:
« Odgovori #639 : 17 Srpanj, 2018, 11:51:59 »
I onako neces cut muziku u voznji đabe ti to :P
