Autor Tema: eBay/Aliexpress/Skuter shopovi - fancy stvari, dobre ponude, popusti, akcije  (Posjeta: 678822 )
Offline Ivan46
  • Postova: 1183
  • 2t power by Hello Kitty
  • Moja Kaciga: Vemar
  • MojSetup: xenon+neon
  • MojSpuh: Akrapovic
Odg: Ebay fancy stvari
« Odgovori #700 : 12 Rujan, 2018, 16:57:05 »
evo napokon mi stoka kineska odgovorila,izgleda da ce mi vratiti novce.
In order to protect your buyer protection, we agree to refund you.
But we need confirm,
1) we could refund you first, but
Could you kindly pay back to us when you receive later?
If you really need, it, if not receive, is it ok to reorder?
2) For a store, neutral feedback is the same with Negative feedback .
Appreciated that you could give 5 stars feedback to us.
Hope for positive feedback , or no negative neutral feedback.
We will improve our service better.
I'm just a Staff ,work hard for gain a small amount of wages to live.
Waiting for your reply. please let us know your decision.
Have a question sentence for you, please answer.
Offline gaminator
  • Postova: 10
« Odgovori #701 : 13 Rujan, 2018, 16:39:02 »
Srce mi se cepa na pricu od malog kineza. Al nije smrad napisal kolko ljudi godisnje izjebe koji ga ne traze povrat para.
Offline Ivan46
  • Postova: 1183
« Odgovori #702 : 13 Rujan, 2018, 17:08:08 »
vratili mi novce,ovo je prvi i posljednji put da su me pokusali zjb,odsada cim mi nedode u roku 4tjedna odmah trazim povrat.
« Odgovori #703 : 13 Rujan, 2018, 20:00:54 »
Ma jeftinije nadjem kod nas s garancijom nego preko ebaya, masu stvari.
« Odgovori #704 : 13 Rujan, 2018, 22:03:35 »
Glava me zaboli od kineskog engleskog  :icon_biggrin:
Offline Pupo
  • Postova: 2867
  • Mjesto: ZG/Pž
  • Moj Skuter: Area 51
« Odgovori #705 : 14 Rujan, 2018, 11:38:42 »
Daj nemojte pričat gluposti, svi koji su u stanju koristiti ebay, u stanju su i tražit pare nazad. Svi traže povrat, vjeruj mi.
Što se tiče povrata i svega, ja sam uvijek dobio pare kada mi nešto nije stiglo il je stiglo krivo/sjebano/lošije. Al sam isto tako recimo uplaćivao naknadno selleru ak sam radio dispute za povrat jer mi nije stiglo u xy dana i dobio povrat, al mi je ipak stiglo kasnije.
I neznam kak vas neko može zajebat preko ebaya, produžili su rok na mislim 90 dana za žalbe.
Offline Lezz22
  • Postova: 269
  • Moj Skuter: Speedfight 2
« Odgovori #708 : 18 Rujan, 2018, 14:04:41 »
Je kupovao tko gps lokator nesto ovako
https://www.aliexpress.com/item/Realtime-GSM-GPRS-GPS-Locator-Car-Vehicle-Tracker-TK110/2011673763.html?spm=2114.search0204.3.41.2e006926H2Mnay&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_5017611_10059_10696_100031_10084_10083_10103_451_10618_452_10307_10820_5017711_10301_10821_10303_5017411_5017511,searchweb201603_54,ppcSwitch_7_ppcChannel&algo_expid=4ba9036c-9aa2-40aa-a6c1-850dbbe30471-6&algo_pvid=4ba9036c-9aa2-40aa-a6c1-850dbbe30471&transAbTest=ae803_1&priceBeautifyAB=0
Ak neko ima il je imao bio bih zahvalan za cut iskustva hah
Gdje zivis?
Rijeka, al strah me ostavljat ga digod, svako malo se pokoji ukrade a s ovim bi ga nasao ako nista bar rastavljenog  ::)
I narucio sam si ali samo gps tracker pcb tj. plocicu pa ce na nju ic li-po od 3000-4000mah i sve u elektricnu kutijicu vodonepropusnu pa kad se odspoji sa aku da traje baterija jos tj dana jer gledao kinezi sve stavljaju 100mah bateriju pa traje 1-2h samo ...
« Zadnja izmjena: 18 Rujan, 2018, 14:11:47 Lezz22 »
Offline Pupo
  • Postova: 2867
  • Mjesto: ZG/Pž
« Odgovori #709 : 18 Rujan, 2018, 14:52:22 »
Frend mi je radio u firmi koja se tim bavi. Kaže da ak je netko maher tko krade, da nažalost tracking ništa ne vrijedi. Al da, od narkića i ovih sitnih kradljivaca si siguran s tim.
Offline Lezz22
  • Postova: 269
« Odgovori #710 : 18 Rujan, 2018, 15:57:42 »
razmisljao i o tom ali planirao sam da to probam ugradit negdje tipa u zadnji far ili tako negdje u vecem dijelu di bi se vec dalo sakrit a i nije toliko ogromno jer ako netko i gleda to onda bi trazio po rami negdje (logicno razmisljanje) samo neznam vidit cu kad mi dodje koliko veliko bude pa ga u neku komponentu ubacim tipa sat, far, stop, cak sam razmisljao i u retrovizor jer u one malo deblje stane vjv
  • Postova: 1613
« Odgovori #711 : 20 Rujan, 2018, 11:45:04 »
Aha a ovaj forum citaju samo pozitivci. Ovi sto kradu i dilaju djelove nece procitat tvoj post u kojem ces im tocno rec di si ga ugradio;-))
Offline Lezz22
  • Postova: 269
« Odgovori #712 : 20 Rujan, 2018, 12:00:34 »
Sad ide unutar felge  :toothy9:
Sto je jos bolje moze se lako ugradit, napravit bezicni punjac i pcb zaljepit smolom il dvije metalne plocice i zavarit unutar samo neznam kolika bi muka bila stavljat i micat gumu  :-X
btw takodjer planiram ubacit 2 way alarm samo sta bi alarm ugasio pa da mi samo javi na daljinski, skuter ce imat vecu tehnologiju nego danasnji auti   :toothy10:
  • Postova: 1613
« Odgovori #713 : 20 Rujan, 2018, 22:28:31 »
...i airbag ugradit u sic i elektro shoker na rucke pa trignes na daljinac kad vidis da ga baja zajasi :headbang:
Offline OUC AIR
  • Postova: 525
  • garage my home
    • bmw forum
  • Mjesto: skvot
  • Moj Skuter: negdje
  • Moja Kaciga: crna
  • MojSetup: postelani usis
« Odgovori #714 : 09 Listopad, 2018, 12:28:35 »
bammmmm prm pr pr 095 5193695
  • Postova: 6807
« Odgovori #716 : 11 Studeni, 2018, 19:38:39 »
Ima ga frend na kvadu, dobar je nije los i ljepo se cuje jedino je bez db kilera malo preglasan
Offline Pupo
  • Postova: 2867
  • Mjesto: ZG/Pž
« Odgovori #717 : 11 Studeni, 2018, 19:51:34 »
Fakat gore pise akrapovic?
  • Postova: 6807
« Odgovori #718 : 11 Studeni, 2018, 20:35:36 »
Da....
« Odgovori #719 : 30 Prosinac, 2018, 07:29:17 »
Zvuk ove kopije nema veze s originalom. Ove krom kic sjajne obujmice ga odmah izdaju. Al dobro su ga iskopirali.
