Autor Tema: 2007 Aprilia SR50 (Jorge Lorenzo #48 Replica)  (Posjeta: 8739 )
Offline Marekk
  • Postova: 638
  • Mjesto: Bedekovčina
  • Moj Skuter: '07 SR 50R Lorenzo
  • Moja Kaciga: Airoh Stelt
  • MojSetup: Due+ Limited
  • MojSpuh: Yasuni C16/07
« : 03 Srpanj, 2012, 22:13:56 »
Još jedna nova SRka.
2007 godina, kupljen od prvog vlasnika, 11.8,2012.,  ima samo 7,000 km, potpuno original stanje. Svi paprir, računi, servisna.
Spain's no.1 Replica (Jorge Lorenzo #48), baš takvu sam htel, inale to je druga po redu, prvu sam imal mjesec dana pa kupil ovu, koja je salon stanje  :icon_thumright:
Naravno, nije ostala dugo serijala, pošto je doma od one prve več bio auspuh S6R R1200, i MHR Replica 70cc, bilo je pitajne kaj složit, prodat spuh i kuput Yasuni R, ili uzet jači kit, naravno da se odlučio na slaganje Racing setupa  :icon_biggrin:
Kaj je u konačnici rezultiralo sljedećim setupom:
Engine:
- Stage6 Racing mkII 70cc cylinder kit
- Stage6 Racing R1200 exhaust
- Ported engine case by P.M.W.
- BGM Pro Evolution crankshaft
- NTN main bearing, metal cage (Japan)
- Corteco Viton seals
- Malossi MHR needle bearing (12×17×16)
- NGK BR10EVX spark plug
- Top Performances Woodruff key (3° earlier ign.)
Intake:
- Motoforce PWK 24mm (PowerJet)
        - main jet 120
        - pilot jet 40
        - power jet 32
- Motoforce filter double layer d=50mm
- Kiesler intake manifold 34mm (35°)
- Stage6 Racing MBR reed cage
- Stage6 Racing Fiberglass reeds (0.35)
Transmision:
- Stage6 Racing R/T Oversize Vario
- Stage6 Racing Torque control mkII clutch
- Stage6 Racing R/T CNC Clutch bell 460g
- Stage6 Racing Torque spring (medium/orange)
- Malossi MHR H.T.Q. Primary gears +27% (14/39)
- Malossi Torsion control
- OEM drive belt
Tuning & Styling (other) :
- Bridgestone Molas ML50 13" (130/60 & 140/60)
- powdercoated white rims
- Stage6 SSP kickstarter (matte black)
- Stage6 white 3M reflective rim stickers
- BGM yellow fuel hoses
- Progrip 732 yelow grips
- TrailTech TTO digital RPM meter
- buzzetti sidestand
- Piaggio ignition cover (till 1999)
- HM waterpump drive limiter (no oil pump)
- Aprilia SR50 '03 front mudguard (yellow)
- Gilera Runner 2010 rear mudguard
- 3M carbon foil on forks
etc...
« Zadnja izmjena: 17 Travanj, 2013, 12:32:27 Marekk »
Offline Marekk
  • Postova: 638
Odg: 2007 Aprilia SR50 (Jorge Lorenzo #48 Replica)
« Odgovori #1 : 04 Srpanj, 2012, 11:21:22 »
za komentare i tijek projekta pogledajte ovdje
http://www.mojskuter.com/forum/index.php/topic,71818.0.html
« Zadnja izmjena: 23 Studeni, 2012, 22:14:30 Marekk »
Offline Marekk
  • Postova: 638
« Odgovori #2 : 24 Lipanj, 2013, 17:52:12 »
Da obnovim info o trenutnom (vjerojatno i bude tak ostalo) setupu SRke.
Naime početkom svibnja 2013 skuter je bio složen s onim gore Racing setom dijelova, ali nakon samo 1 sat vožnje s njima (još nije bilo ni uštelano) mještani se žalili policiji radi buke užasne, pa sam sve to poskidao dole dok je još mir bio.
I odma drugi dan naručio dijelove da sklopim mašinu koja bude ko serijala trajala a da s emožeš normalno vozit, pa sam kupio:
- Stage6 Streetrace
- Yasuni R alu (update: nakon mjesec dana se preporodio kupivši novi Yasuni City16 Kevlar)
- Malossi Multivar2000
- Dellorto PHBG 19 BD
    - glavna 78
    - ler 50
    - igla W7 (2. zub odozdo)
    - klipić 40
- Polini blue panel filter
- Stage6 NBR usisni blok (0.30mm fiberglass reeds)
- Polini opruge kvačila (žute)
- NGK BR9EG
a sjeli su i neki vizualni dodatci kao:
- Galfer 260mm prednji disk
- crveni čepovi volana
« Zadnja izmjena: 09 Listopad, 2013, 23:09:29 Marekk »
