Autor Tema: Malaguti Phatnom F12 - Setup  (Posjeta: 7850 )
Offline pave_f12
  • Postova: 269
  • Moja Kaciga: lipe boje
  • MojSetup: bit ce i kita
  • MojSpuh: bit ce auspuha
Odg: Malaguti Phatnom F12 - Setup
« Odgovori #80 : 05 Ožujak, 2011, 18:35:32 »
e da cuo sam da baca u stranu na onoj strani kojoj je disk, ali ja to bas nisan nikad primjetia jer je disk manji valjda  :dontknow:  ako ce mi se to dogadat onda nezelim veci disk nego ovaj normalan. sta ti kazes ?
« Odgovori #81 : 06 Ožujak, 2011, 00:07:55 »
imas za pristojen novce  (oko 100e) 240mm od s6 savim dovoljan. javi se efzu i naruci prek web shopa
Offline pave_f12
  • Postova: 269
« Odgovori #82 : 06 Ožujak, 2011, 01:04:17 »
ja san jedino ovo nasa od s6 i jedino na ovoj stranici. ovo su oversize. nisan te razumia da uzmen oversize ili ne ?
Brake Disc Stage6 Oversize 250 mm - Steel
This new wavey oversize brake disc from Stage6 is now available for the Malaguti F12 with 3-hole brake disc mount and has a full 250 mm diameter. As you know it from oversize systems, this one is also available either made of steel or stainless steel. The steel version has much better braking power than the stainless steel version but is of course more prone to rust. So you will have to choose between performance and style. The 6-point floating brake disc comes in a new design and will be used with the included brake calliper.
cijena 125 eura. nije li to malo previse za jedan disk ? mislin neznan nisan nikad kupova diskove  :dontknow:
« Zadnja izmjena: 06 Ožujak, 2011, 01:06:00 pave_f12 »
« Odgovori #83 : 06 Ožujak, 2011, 02:51:17 »
jebi ga ima i skupljih
vidim f12 je poseban nema kao za ostale s 3 rupe 240-260-280  :dontknow:
ne vidim razlgog da se ne moze upasat 240 lako za distancer  :toothy11:
rekao sam ako vec oces oversize nemoj prejerivat s velicinama
Offline pave_f12
  • Postova: 269
« Odgovori #84 : 07 Ožujak, 2011, 12:46:53 »
aha ok. znaci nebude li prevelik nece bacat u stranu ? a nazad sta da stavin ?
Offline pave_f12
  • Postova: 269
« Odgovori #85 : 08 Ožujak, 2011, 17:45:12 »
jel moze odgovor ? znali iko ?
