Autor Tema: SPORTCITY ONE 50 STREET 2T - setup preporuka  (Posjeta: 17896 )
Offline motorin_one
  • Postova: 25
  • Moj Skuter: Aprilia SPORTCITY 50 One 2T
  • Moja Kaciga: Nolan N-84
  • MojSetup: Malossi MHR Replica AC
  • MojSpuh: LeoVince Touring
« : 14 Kolovoz, 2010, 00:09:38 »
Pozdrav svima!
Prije godinu dana sam kupio Apriliu SPORTCITY ONE 50 STREET 2T.
http://www.aprilia.com/en-US/Model/11893/SPORTCITY+ONE+50+STREET/Technical.aspx
Na skuteru je sva serijala, a prešao sam 5000 km, gradske vožnje (male dionice, 5-10 km). Sada bi htio malo "ojačati" stroj a da pri tom zadovolji sljedeće kriterije:
-Svakodnevna vožnja bez štelanja i servisa svakih stotinjak kilometara
-Trajnost, u normalnim okolnostima želio bi par godina, uz redovito servisiranje
-Razumna potrošnja, ne preko 7L/100km
-Dobar start, tako da mi auti na semaforu nisu na repu već nakon 20 metara
-Veća krajnja brzina, sa 100 km/h bi bio zadovoljan
-Buka šta je moguće manja i sam zvuk nježniji za uši okoline
-Sve ovo uz otegotne okolnosti (mojih 110 kg i povremeni suputnici)
Za ostvarenje navedenog razmišljam o sljedećem setup-u:
-Kit Malossi MHR Replica 70cc
http://www.sip-scootershop.com/EN/Products/M318463/Racing+cylinder+68cc+MHR.aspx
-Auspuh Yasuni R (Alu)
http://www.sip-scootershop.com/EN/Products/YA420AL/Rennauspuff+YASUNI+Scooter+R+PIAGGIO+ACLC+epass.aspx
-Variator Multivar 2000 Malossi
http://www.sip-scootershop.com/EN/Products/M519019/Variator+MALOSSI+Piaggio.aspx
-DELTA Clutch + WING Clutch BELL KIT
http://www.sip-scootershop.com/EN/Products/M5214110/DELTA+Clutch++WING+Clutch+BELL+KIT+PIA.aspx
-Air filter MALOSSI Piaggio AC Red Sponge
http://www.sip-scootershop.com/EN/Products/M1411778/Air+filter+MALOSSI+Piaggio+AC.aspx
-Iridium svjećicu
http://www.sip-scootershop.com/EN/Products/88621000/Spark+plug+DENSO+IWF24+Iridium.aspx
-SKF ležaje za radilicu
http://www.sip-scootershop.com/EN/Products/C16380KTV/Bearing+crankshaft+HQ+GILERA.aspx
-Belt MALOSSI Kevlar special
http://www.sip-scootershop.com/EN/Products/M619535/Belt+MALOSSI+Kevlar+special+.aspx
druge odgovarajuće djelove (opruge, dize i sl.)
Molim članove za savjete, sugestije, preporuke za slaganje (ko bi bio voljan to dobro složiti-naravno uz naknadu). Unaprijed hvala! :icon_thumright:
Somehow "we couldn't have foreseen" and "we're confident it will not happen again" don't fit very well together.
Offline Faba
  • Postova: 1392
Odg: SPORTCITY ONE 50 STREET 2T - setup preporuka
« Odgovori #1 : 14 Kolovoz, 2010, 00:16:18 »
Pozdrav svima!
-Iridium svjećicu
ovo u vezi sa servisiranjem i potrosnjom mogo bi proc i neki jaci midrace  :laughing7:
fali ti karb 19,komplet dizni,neka igla,prerada airboksa,bolji usis,mozda jaca radilica,rolice,federcici,feder,mozda produzeni prijenos i takve stvari  :icon_thumright:
« Odgovori #2 : 14 Kolovoz, 2010, 00:51:09 »
Setup ti je manje više ok. Iako, ako ciljaš na što manju buku, zaboravi yasuni.
Btw, ja bih to ovako složio: tp trophy, leovince touring, dellorto 19, malossi multivar, bgm radilica i getriba od lc-a.
« Odgovori #3 : 14 Kolovoz, 2010, 08:25:09 »
ak već ima para bolje alu jer je zračnjak..
ako uzima leo vince touring (isto preporuka) dosta će biti serijski karb 17.5 da se malo preuredi..
kvačilo može ostat serijsko čak sa serijskim federima na njemu jer touring tako radi...
Offline motorin_one
  • Postova: 25
« Odgovori #4 : 14 Kolovoz, 2010, 14:00:02 »
@gorkiSP
moje glavno pitanje je dali bi se moj navedeni setup (+ koja je preporuka za 19 karb - ako se serijski neda naštimat) mogao dobro posložiti, tako da skuter bude za svakodnevnu vožnju, bez šarafljenja i štelanja svakih stotinjak km i procjena dali serijska radilica može nositi ovaj setup.
@ivanm
obzirom na način korištenja (centar grada, start-stop-start-stop) kvačilo bi svakako htio jako dobro. Kakva su iskustva sa štelanjem serijskog 17,5 karba?
Yasuni bi htio zbog kvalitete i snage, a buka je požena što manja.
« Odgovori #5 : 14 Kolovoz, 2010, 14:18:24 »
Može i taj 17.5 raditi, ali nije neka sreća, zato bi ja u svakom slučaju uzeo 19. Setup ti je ok, kao što rekoh. Yasuni r izvlači iz replice fine performanse, i ako se dobro složi (naštela), ako se dobro održava (ulje, grijanje i sl.) ne bi trebalo biti problema. Radilica može neko vrijeme držati taj setup, ali bilo bi dobro promijeniti ležajeve i igličasti. Ja bih ipak i tu dao 100€ više i uzeo bgm radilicu, onda si sigurna da će izdržati.
Offline motorin_one
  • Postova: 25
« Odgovori #6 : 14 Kolovoz, 2010, 14:38:23 »
@gorkiSP
Ali šta je sa "štelanjem"? Dali se to sve da složiti i da skuter koristim uz normalno održavanje :dontknow:
Bez novih ležajeva ni u ludilu :nono: :nono:
Šta se tiče radilice, ako serijska može držati, nebi je mjenjao
I koji točno 19 karb bi stavio umjesto serijskog?
Htio bi naći nekoga da mi sve odabrano dobro posloži i da mogu skuter koristiti svakodnevno, a ne ne svako dva dana u garažu.
« Odgovori #7 : 14 Kolovoz, 2010, 14:47:34 »
Pa napisah, ako se u startu sve dobro složi i naštela, nema potrebe za daljnjim štelanjem. Evo za primjer, 3alfa3, imao je replicu, yasuni r, dellorto 19, multivar, delta...ugl. napravio je lijepe kilometre s tim setupom, bez da je bio ispod njega svaki dan.
Offline motorin_one
  • Postova: 25
« Odgovori #8 : 14 Kolovoz, 2010, 15:02:24 »
@gorkiSP
Zahvaljujem na odgovoru :icon_thumright:, poznat mi je primjer od 3alfa3 :notworthy:
Nego, preporuka za nekog ko bi se htio pozabaviti poslom? 3alfa3 :hello:
« Odgovori #9 : 14 Kolovoz, 2010, 15:03:47 »
slažem se s ivanm da bi bilo bolje alu uzeti jer gus će mu stradavati po ljeti, obavezno 19ka na ovaj setup, i auspuh bi mogao možda neki koji neće vrtiti kao yasuni, malo že se potrošnja smanjiti a mislim da je yasuni i malo glasniji od ostalih  :icon_scratch: mislim, tiši je od narda, al ono  :toothy3:
ovo je jako dobar setup, samo kad se već blokovi rastavljaju daj neku radilicu s punim polutkama uglavi, to ti je još +100€ a napravit ćeš uslugu i samom sebi a i skuteru
mislim da je ovo prvi sportcity ozbiljniji projekt na forumu, samo naprijed, ako treba šta pomoć još viči  :icon_thumright:
Offline motorin_one
  • Postova: 25
« Odgovori #10 : 14 Kolovoz, 2010, 15:19:12 »
@Iwo SR Tuono
Hvala na ponudi :icon_thumright:
Kad bi se našao neko ozbiljan i iskusan da sve posloži :toothy10:
Možda bi bilo dobro dodati i ovo:
Racing crankshaft MALOSSI
http://www.sip-scootershop.com/EN/Products/M537600/Racing+crankshaft+MALOSSI.aspx
Carburetor kit MHR 19mm
http://www.sip-scootershop.com/EN/Products/M1611021/Carburetor+kit+MHR+19mm.aspx
« Odgovori #11 : 14 Kolovoz, 2010, 15:23:25 »
to je to
« Odgovori #12 : 14 Kolovoz, 2010, 15:31:26 »
Javi adresu i dođemo ti to složiti ivo i ja  :laughing7:
Btw, nema potebe plaćati malossi duplo, jer ti je i ova dovoljna, za duplo manju cijenu
http://www.sip-scootershop.com/EN/Products/R10030201/Racing+crankshaft+RMS+PIAGGIO.aspx
Offline motorin_one
  • Postova: 25
« Odgovori #13 : 14 Kolovoz, 2010, 15:44:22 »
@gokiSP
Ovo za RMS je iz iskustva ili ... :icon_scratch:
Gledam i ovu:
Racing crankshaft KIESLER
http://www.sip-scootershop.com/EN/Products/KS100200/Racing+crankshaft+KIESLER+Racing+GILERAPIAGGIO.aspx
dali ko ima kakva iskustva i dali odgovara (conrod 90mm)  :dontknow:
A šta se tiče posla, dečki ako ste zainteresirani samo dajte, ili imate koga za preporuku.
« Odgovori #14 : 14 Kolovoz, 2010, 15:58:45 »
RMS, BGM i još jedna marka (ne mogu se sjetiti koja) su skoro iste radilice, i definitivno su best buy sve do nekakvog mid race kita. Vjeruj mi da ti ne treba jača radilica, osim ako ti voliš platiti više  :icon_biggrin:
Offline motorin_one
  • Postova: 25
« Odgovori #15 : 14 Kolovoz, 2010, 16:02:45 »
@gokiSP
Hvala :icon_thumright:
Šta se tiče plaćanja, ja bi platio koju pivu više dobrom "majstoru" :toothy10:
« Odgovori #16 : 14 Kolovoz, 2010, 17:08:46 »
mogu ti ja složiti..
« Odgovori #17 : 14 Kolovoz, 2010, 18:40:02 »
svječka mora biti dugi navoj, Denso IW27 ili W27 ESZU (ova 24 kratki navoj je za minarelli serijalu)
NGK BR9EIX ili BR9EVX..
Offline motorin_one
  • Postova: 25
« Odgovori #18 : 18 Kolovoz, 2010, 21:30:00 »
Hvala svima na sugestijama!  :icon_thumright:
Sa Ivanom sam dogovorio slaganje i idu ovi djelovi:
-Racing cylinder 68cc "MHR Replica"
-LeoVince Touring
-Racing variator "Multivar" MALOSSI Piaggio - Gilera 2000
-Spark plug DENSO IW27 iridium
-Jets set DELLORTO 6mm, size: 75-98
« Zadnja izmjena: 26 Rujan, 2010, 23:14:47 motorin_one »
« Odgovori #19 : 18 Kolovoz, 2010, 21:30:45 »
A karb?
