Autor Tema: Pozdrav skuterasi...  (Posjeta: 5285 )
Offline beetleman
  • Postova: 29
« : 18 Kolovoz, 2006, 11:00:16 »
Neki me znaju sa motori.hr, ponosni sam vlasnik Piaggio Vespe PX-200 iz 89.g.
Slika u prilogu:
trenutno je u fazi uredjivanja.. :) :)
Kratak info:
Overall Length:      1760 mm (69.3 in)
Overall Width:       695 mm  (27.3 in)
Overall Height:      1110 mm (43.7 in)
Wheelbase:           123 5mm (48.7 in)
Ground Clearance:    225 mm  (8.9 in)
Dry Weight:          108 kg  (238 lb)
Chassis No. Prefix:  VSX 1 T
Engine  No. Prefix:  VSE 1 M
Typical Speeds:
Top:                 120 kph (75 mph)
Cruise:              104 kph (65 mph)
Engine
Type:         Single cylinder fan-cooled two stroke
Bore:         66.5 mm (2.618 in)
Stroke:       57.0 mm (2.240 in)
Displacement: 197.97cc (12.080 cu in.)
Compression:  9.8:1
Cylinder
Type:         Cast Aluminum Alloy
Cylinder Barrel
Type:         Cast Iron
Bore Sizes:   66.5 mm (2.618 in)
1st Oversize: 66.7 mm (2.626 in)
2nd Oversize: 66.9 mm (2.634 in)
3rd Oversize: 67.1 mm (2.642 in)
Piston
Standard Diamter:    66.292 mm (2.6099 in)
Oversizes:           3, in 0.2 mm (0.0079 in increments)
Ring free end gap:   0.025-0.040 mm (0.010-0.016 in)
Crankshaft Assembly
Max. Runout
At mainshaft ends:   0.03mm (0.0012 in)
At flywheel faces:   0.02mm (0.0079 in)
Clutch
Type:                     Wet, Multiplate
No. of Friction Plates:   3
No. of Plain Plates:      2
Gearbox
Type:                      4 speed constant mesh
Ratios:
1st Gear:                  14.47:1
2nd Gear:                  10.28:1
3rd Gear:                  7.31:1
4th Gear:                  5.36:1
ushirlo
  • Gost
Odg: Pozdrav skuterasi...
« Odgovori #1 : 18 Kolovoz, 2006, 11:14:30 »
ponosni vlasnik...........
jesi to ponosan sam po sebi.....pa si još i vlasnik te dvokolice...........
ili si ponosan što si vlasnik dotične.........
jerbo ponosan na vlasništvo može biti samo truli kapitalista..........
Offline beetleman
  • Postova: 29
« Odgovori #2 : 18 Kolovoz, 2006, 11:23:13 »
trenutno sam samo ponosan.. dvokolica je tu da me vozi...  :)
ushirlo
  • Gost
« Odgovori #3 : 18 Kolovoz, 2006, 11:26:00 »
onda dobrodošao ...... druže............
Offline r.e.!
  • forumski penzioner®
  • Postova: 2246
  • Vespa-institucija na dva kota?a
  • Mjesto: Gospi?
  • Moj Skuter: Vespa PX150D Vespa GTS250i.e.
« Odgovori #4 : 18 Kolovoz, 2006, 11:28:00 »
Pozdrav stari :hello: :hello:
Drago mi je da si ovdje. :wave:
"Sembra una vespa"
BELLA MACCHINA
Ja ne znam Eladiove planove
Offline beetleman
  • Postova: 29
« Odgovori #5 : 18 Kolovoz, 2006, 11:29:29 »
bok bok.. reko svi pricaju o tom forumu. pa da se prikljucim.. :) a vidim da ima i podforum za vespe..nice.. :)
Offline r.e.!
  • Postova: 2246
  • Mjesto: Gospi?
« Odgovori #6 : 18 Kolovoz, 2006, 11:35:42 »
radimo, radimo...
pomalo, pa ćemo i Klub osnovat...
"Sembra una vespa"
BELLA MACCHINA
Offline beetleman
  • Postova: 29
« Odgovori #7 : 18 Kolovoz, 2006, 11:49:47 »
bilo bi i vrijeme... :) :toothy10:
Offline enigma
  • Postova: 1237
  • Mjesto: Pula
« Odgovori #8 : 18 Kolovoz, 2006, 20:52:06 »
dobar glas daleko se čuje... :toothy10:
pozdrav :hello:
Offline eladio
  • We are the Borg
  • administrator
  • Postova: 9355
  • Moj Skuter: Xciting 400i
  • Moja Kaciga: SMK Hybrid
  • MojSpuh: Yasuni black ed.
« Odgovori #9 : 18 Kolovoz, 2006, 21:00:47 »
dobro dosao..  :icon_thumright:
PS
tko to prica?  :icon_biggrin:
PPS
ushirlo.. sve clanove ravno pa napadnes, ajde nemoj, platit cu pivo  :toothy9:
Offline filiplatinovicz
  • forumski djed
  • Postova: 3894
  • COITO ERGO SVM
  • Mjesto: Zagreb, Centar
  • Moj Skuter: Vespu GT 200, Vespu PX 200E, Piaggio Skipper 125 4T, Peugeot X-fight (cvajo 50 ccm) i sve drugo što mu dosta ?esto do?e pod yay?eka
« Odgovori #10 : 03 Studeni, 2006, 05:20:49 »
dobro dosao... TZvoje se vespe sjećam s motora....  :toothy12:
www.MAGNETIX.hr
   www.MAGNETIX.hr
      www.MAGNETIX.hr
 ADVANCED TEHNOLOGY DESIGNED TO PROTECT
Offline Hrastinski
  • Postova: 612
  • Mjesto: Zabok
  • Moj Skuter: Runner 50
  • MojSpuh: tt
« Odgovori #11 : 03 Studeni, 2006, 11:26:49 »
dobro došao!!! :hello:
Offline Mr J
  • Postova: 6214
  • Moj Skuter: HD V-Rod
  • Moja Kaciga: Schuberth R1
  • MojSetup: Uvijek spreman!
  • MojSpuh: Protočan :)
« Odgovori #12 : 03 Studeni, 2006, 12:23:24 »
oj!  :hello:
  • forumski djed
  • Postova: 3894
  • COITO ERGO SVM
« Odgovori #13 : 04 Studeni, 2006, 05:56:42 »
... ima ovdje puno vespoljubac...  :toothy9:
www.MAGNETIX.hr
   www.MAGNETIX.hr
      www.MAGNETIX.hr
