Autor Tema: Server not found :s  (Posjeta: 1580 )
Offline zL!Ko
  • Postova: 558
  • volim ritam roka i turbofolka
  • Mjesto: Crikvenica
  • Moj Skuter: DT 125
  • Moja Kaciga: bez vizira
  • MojSetup: /
  • MojSpuh: ser.
Server not found :s
« : 28 Veljača, 2010, 10:38:26 »
Taj tekst mi se pojavi svaki put kad se pokusam spojit na ms. Probao sam preko oba kompa al nece nikako. Ako sta znaci oba kompa su spojena na isti modem. Ovo pisem preko moba jedino mi  tako radi. Aj plz neko
Offline efz
  • administrator
  • Postova: 2623
  • Mjesto: Zabok
  • Moj Skuter: Versulja 650
  • Moja Kaciga: SchuberthS1 PRO
Odg: Server not found :s
« Odgovori #1 : 28 Veljača, 2010, 10:44:00 »
Evo sta je eladio napisao post ispod:
nesto su se DNSovi posemerili...
uglavnom opet se sve propagira,
evo upute kako mozete pristupiti serveru prije nego vam se propagira standardnim putem :
otvorite wordpadom file /windows/sistem32/drivers/etc/hosts
upisite jos u taj file ovo :
83.169.34.20 mojskuter.com
83.169.34.20 www.mojskuter.com
u konacnici to izgledao ovako :
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
127.0.0.1       localhost
::1             localhost
kroz 4 sata bi svima ipak trebao proraditi site  :redface:
Sve za skuter/vespu - MStrgovina.hr
- tuning & styling dijelovi
 - gume
  - akumulatori
   - ulja
Offline zL!Ko
  • Postova: 558
  • MojSetup: /
  • MojSpuh: ser.
« Odgovori #2 : 28 Veljača, 2010, 10:53:08 »
Ok. Hvala, al imam linux pa nemogu tako. Cu probat popodne.
EDIT: 11:35 sve radi normalno :headbang: :headbang:
« Zadnja izmjena: 28 Veljača, 2010, 11:35:52 zL!Ko »
