OSJETI CESTU Sve za skuter!!
Autor Tema: P: Paintball oprema  (Posjeta: 1173 )
Offline Mr J
  • Postova: 6283
  • Moj Skuter: Peugeot Satelis 500
  • Moja Kaciga: Schuberth R1
  • MojSetup: Uvijek spreman!
  • MojSpuh: Protočan :)
P: Paintball oprema
« : 02 Kolovoz, 2009, 22:20:47 »
Prodajem sljedecu paintball opremu, u kompletu ili pojedinacno.
MARKER
Smart Parts SP-1:
* Mil-spec accessory rails at every angle and integrated mount points for a stock, the SP-1 is ready for a limitless variety of accessories.
* Equipped with an integrated tactical flashlight mount right below the barrel, which accepts inexpensive focused beam flashlights at a fraction of the cost of expensive tactical flashlights.
* Low pressure electropneumatic operation replaces the outdated spring and hammer designs that power competing tactical markers, and allows the SP-1 to deliver a fast , accurate and quiet hailstorm of paint.
* Weight (marker only): 2 lbs. 6 oz.
* Length (w/out barrel): 12.5 in.
* Operating Pressure: 180psi
* Gas Source: HPA or CO2
* Anti-Chop System: Low force bolt
* Trigger Pivot: Stainless steel pin
* Ball Detent: Dual rubber style
* 3 Firing Modes: Full Auto, Semi-Auto, and 3-Round Burst
* Max Rate of fire: 15-17bps
* Field legal mode lock
* Runs on one 9 volt battery
* Standard ASA included
* One piece 10 inch barrel
* Feedneck: Vertical clampingGlass fiber reinforced nylon grip frame/body
*** u orginal kutiji, na poklon se dobivaju: cistilica, kondom za cijev, gravitacijski loader, 2 manja pota za kuglice
*** markerom je igrano svega 3 puta (cca. 3000 kuglica)
1100,00 kn
BOCA za CO2
* 20 OZ - veliki kapacitet (jedno punjenje dovoljno za karton boje 2000 komada)
* pin ventil
* Brza i jednostavna montaza i demontaza
200,00 kn
MAMBA
* NEKORISTENA
* slide check
250,00 kn
LOADER
Evolution 2 (EGG)
* koristen samo jednom (cca. 1000 kuglica)
*The all new eVLution™ II with Y-Board™ force feed electronic loader won't starve your marker, no matter how fast you shoot. The eVLution™ II with Y-Board™ features a feed rate that matches a marker's optimal fire rate up to 19 balls per second, a specially designed feeding propeller with new flexible blades
400,00 kn
MASKE
Dye i3
* malo koristena
* Profesionalna maska za paintball
*A product designed to protect your most important features deserves to be extraordinary. That is why the design team at Dye has harnessed the power of performance and style to create the Invision 3 with Tri-Mold Soft Flex Technology. A firm upper frame, co-molded with a soft dual-density, mask delivers a functional yet stylish advantage over the competition. This new technology sets the standard for comfort, flexibility and safety
350,00 kn
Rekreativna maska za paintball koristena svega 2 puta
*termalno dvostruko staklo
100,00 kn
KOMPLET 2000,00 kn plativo u 2 rate!!!
kontakt : 095 900 41 34
*** Cijene nisu fixne, moguc je neki popust za gotovinu i za ozbiljne kupce ukoliko se uzima vise artikala...
*** Garancija na svu opremu
« Zadnja izmjena: 02 Kolovoz, 2009, 22:23:51 Mr J »
Offline Mr J
  • Postova: 6283
Odg: P: Paintball oprema
« Odgovori #1 : 11 Kolovoz, 2009, 09:28:38 »
Ajde na prvu stranicu!
Cijene padaju kao kisa...  :icon_thumright:
Sve za skuter!!
