Autor Tema: Jel madison 3 od 125 brži od nexusa 125  (Posjeta: 4378 )
Offline Dino st
  • Postova: 82
« : 22 Travanj, 2009, 12:47:11 »
General information
Model:   Gilera Nexus 125
Year:   2008
Category:   Scooter
Rating:   71.6 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement:   124.00 ccm (7.57 cubic inches)
Engine type:   Single cylinder
Stroke:   4
Power:   14.50 HP (10.6 kW)) @ 9750 RPM
Torque:   11.70 Nm (1.2 kgf-m or 8.6 ft.lbs) @ 8000 RPM
Compression:   12.0:1
Bore x stroke:   57.0 x 46.0 mm (2.2 x 1.8 inches)
Fuel control:   SOHC
Ignition:   Electronic inductive discharge
Starter:   Electric
Cooling system:   Liquid
Gearbox:   Automatic
Clutch:   Dry centrifugal type with damping plugs
Physical measures
Weight incl. oil, gas, etc:   186.0 kg (410.1 pounds)
Seat height:   810 mm (31.9 inches) If adjustable, lowest setting.
Overall length:   2,100 mm (82.7 inches)
Overall width:   780 mm (30.7 inches)
Wheelbase:   1,530 mm (60.2 inches)
Chassis and dimensions
Frame type:   Double cradle trellis made of high-strength steel tubes
Front suspension:   elescopic hydraulic fork with ö 35 mm shafts;
Front suspension travel:   94 mm (3.7 inches)
Rear suspension:   Double hydraulic shock absorber with four-position spring preload
Rear suspension travel:   76 mm (3.0 inches)
Front tyre dimensions:   120/70-14
Rear tyre dimensions:   140/60-14
Front brakes:   Single disc. Stainless steel disk, ö 260 mm, two-piston floating caliper
Front brakes diameter:   260 mm (10.2 inches)
Rear brakes:   Single disc. Stainless steel disk, ö 240 mm, caliper with two opposite pistons
Rear brakes diameter:   240 mm (9.4 inches)
Speed and acceleration
Top speed:   103.0 km/h (64.0 mph)
Other specifications
Fuel capacity:   15.00 litres (3.96 gallons)
Comments:   Euro 3
Further information
Parts and accessories   Check out parts and accessories from our partners. Gilera Nexus 125 accessories
Ask questions   Join the 08 Gilera Nexus 125 discussion group,
the new Gilera forum at Bikez.name or
the new Scooter forum at Bikez.name.
Insurance, loans, tests    Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikes   List related bikes for comparison of specs
Model:   Malaguti Madison 3 125
Year:   2007
Category:   Scooter
Rating:   59.5 out of 100. Show full rating and compare with other bikes
Stroke:   4
Power:   14.75 HP (10.8 kW)) @ 10000 RPM
Torque:   12.00 Nm (1.2 kgf-m or 8.9 ft.lbs) @ 10000 RPM
Bore x stroke:   72.0 x 60.0 mm (2.8 x 2.4 inches)
Fuel system:   Carburettor
Valves per cylinder:   4
Fuel control:   SOHC
Starter:   Electric
Clutch:   Automatic centrifugal dry clutch
Physical measures
Dry weight:   153.0 kg (337.3 pounds)
Seat height:   795 mm (31.3 inches) If adjustable, lowest setting.
Overall length:   1,980 mm (78.0 inches)
Overall width:   790 mm (31.1 inches)
Wheelbase:   1,410 mm (55.5 inches)
Frame type:   High resistance braced tubular steel frame
Front suspension:   Hydraulic fork
Rear suspension:   Swinging engine and 2 hydraulic shock absorbers
Front brakes diameter:   240 mm (9.4 inches)
Exhaust system:   Catalyst exhaust system
Power/weight ratio:   0.0964 HP/kg
Fuel capacity:   9.00 litres (2.38 gallons)
Color options:   Arctic silver, velvet blue, orange, velvet black
Further information
Parts and accessories   Check out parts and accessories from our partners. Malaguti Madison 3 125 accessories
Ask questions   Join the 07 Malaguti Madison 3 125 discussion group,
the new Malaguti forum at Bikez.name or
Offline Dino st
  • Postova: 82
Odg: Jel madison 3 od 125 brži od nexusa 125
« Odgovori #1 : 22 Travanj, 2009, 12:52:53 »
Dry weight od nexusa 125 je 174 kg
Offline Mr J
  • Postova: 6214
  • Moj Skuter: HD V-Rod
  • Moja Kaciga: Schuberth R1
  • MojSetup: Uvijek spreman!
  • MojSpuh: Protočan :)
« Odgovori #2 : 22 Travanj, 2009, 18:17:03 »
trebao bi biti... moment je tu negdje isti, snaga ista, madison je laksi... Ali to su ti nijanse...
Offline Marekvz1
  • Postova: 1666
  • ajmoooo..
  • Mjesto: Varaždin
  • Moj Skuter: Imao sam...
  • Moja Kaciga: Čupa na glavi...
  • MojSetup: Jedino silikonski s Peveca..
  • MojSpuh: Prodao sam...
« Odgovori #3 : 23 Travanj, 2009, 16:26:46 »
isuse koja tema.idi pa probaj.ak je 50 kila lakši a slične su snage naravno da bolje potegne. :binkybaby: :binkybaby:
Vrnul sam se...Tanji nego ikad.....j#bo te led.
Offline gun_rider
  • Postova: 1390
  • Moj Skuter: cvajo 180
  • Moja Kaciga: imam
  • MojSetup: a
  • MojSpuh: imam
« Odgovori #4 : 23 Travanj, 2009, 17:00:52 »
General information
ko je tu lud :icon_scratch:
u svakom slučaju oba su tromo krme, rađe uzmi 200, 250ccm šta već ima jer će ti to dopizdit za 2 dana :)
Info na PM ili 098/979-8453
Offline Marekvz1
  • Postova: 1666
  • ajmoooo..
  • Mjesto: Varaždin
« Odgovori #5 : 23 Travanj, 2009, 17:07:27 »
da,pogotovo nexus 125,preteški a preslabi skuter.
Offline Dino st
  • Postova: 82
« Odgovori #6 : 23 Travanj, 2009, 23:01:57 »
Več mi je dopizdia cilo vrime je na  full gasu
