Autor Tema: pick-up senzor za ducati paljenja  (Posjeta: 5029 )
Offline ive_91
  • Postova: 1257
  • Mjesto: mjesto Luka
  • Moja Kaciga: takachi tk170n
  • MojSetup: malo je 70
  • MojSpuh: zxulja
« : 11 Studeni, 2008, 22:45:14 »
mislim da je ducati ugl. trebam za tomosa, dobio paljenje za nekih 100 kn ducati el. a nema pick up.
pase od vespe px150/px200 mislim barem da pase i tako su mi rekli
Pickup Vespa PX / T5 / PK50-125 / S /
Rush/FL/FL2/XL2/HP/Cosa/Ape
TMP50/FL/2-3/Mix/Rst
mounted with 1 screw
The Pickup is screwed and brazed to the ignition base plate, a little black box. Inside the box is a wire coil, that’s why it’s sometimes known as a coil. It’s counterpart is a revolving magnet set in the wheel. When the magnet moves over the pickup a contact free low voltage current is induced and sent on further to the CDI. The CDI then conducts a powerful impulse to the spark plug through the ignition cable  and spark plug socket to the spark plug which in turn sparks your ignition.
ak netko ima kod nas ili zna di ima a da nije skuplje puno... ili je jeftinije rabljeno kakvo god... samo da radi
Offline filiplatinovicz
  • forumski djed
  • Postova: 3894
  • COITO ERGO SVM
  • Mjesto: Zagreb, Centar
  • Moj Skuter: Vespu GT 200, Vespu PX 200E, Piaggio Skipper 125 4T, Peugeot X-fight (cvajo 50 ccm) i sve drugo što mu dosta ?esto do?e pod yay?eka
Odg: pick-up senzor za ducati paljenja
« Odgovori #1 : 14 Studeni, 2008, 05:28:01 »
pokušaj kod gospodina Horvata, u najboljem servisu Vespe u ovcom dijelu Balkana! Adresa ma www.vespaclubcroatia.com
www.MAGNETIX.hr
   www.MAGNETIX.hr
      www.MAGNETIX.hr
 ADVANCED TEHNOLOGY DESIGNED TO PROTECT
