glavni je, citam i ne vjerujem, koliko covjek moze biti pun gluposti
j#bo te polini evoluš lezajevi
poliamindi kavez je puno slabiji od metalnog zato su polini i malossi od skfa naručili te lezajeve po potrebi uglavnom bolji su i izdržljiviji zbog tig večih kuglica to je sve što mene zanima ima ih i jeftinijih po netu naručit , to kad nekom drugom slažeš motor i ja bi mu stavio te serijske ležajeve , ali kad sebi slažem nešto oču imat najbolje jel tu jednog dana ide team replika gore i ležajevi moraju bit najbolji evo ti od malossija za ležajeve od skf po naruđbi , serijsko je serijsko ,a ja ču više vjerovat poliniju i malossiju i j#bote kaj ste vi tolko škrti sebi kupit tu mi gledate na jebenih 100-200 kuna na najvažniji dio motora
SPECIAL HIGH-SPEED BALL BEARINGS
Crankshaft ball bearings with oversized spherical rollers designed for operating speeds of up to 18,000 RPM and 30 Kw of power.
SKF optimized these new types of bearings, with the collaboration of Malossi's Engineering R&D department, for two stroke scooters and motorcycles competing in the Malossi Trophy series.
Another technological step forward that guarantees greater reliability and performance, qualities gladly accept by the technicians in the field.
Technical Specifications
•High-speed ball bearing with increased operating load
•Eight (
![{$default_cool_smiley} 8)](http://forum.mojskuter.com/Smileys/Lots_O/cool.gif)
spherical rollers increased to 8 mm diameter (*)
•Polyamide cage
•Carbonitrided inner ring
•Outer ring modified by Malossi to improve lubrication (*)
